Air Box Silencer?
Old 04 Apr 2006, 06:48 pm
Default Air Box Silencer?
I've read other posts here about removing the Air Box silencer, (the white hollow tube inside the top of the air box). I removed mine, and to be honest, I don't notice any difference on the way the car sounds. For those who have stated it "sounds better", how does it sound better? Is it louder when you are driving fast with all the windows down? It doesn't seem any loader to me in idle, or when I rev the engine while in park. Also, I don't see how this hollow white plastic tube could even be a silencer. If there were some material inside the tube to muffle sound, maybe. But a hollow tube? It seems more likely to me from my own observation that the tube is there to devert air flow into the intake from the air box. That would explain the bent angle of the tube. Why would a silencer need to be bent at a slight angle? I could be wrong since so many are claiming it to be a silencer, but where did you find out that is its purpose? Is that what Chrysler claims its function is?
Thanks.
Old 06 Apr 2006, 10:37 pm
It's been a while since I removed mine, but if I remember, I didn't hear the whoooosh when I let off the accelerator like I do. Can't say I'm really impressed, but then again, it's one more restrictor between the airbox and the turbo.
Old 07 Apr 2006, 09:20 am
You seem to be looking for confirmation that the white plastic venturi tube and the airbox design is indeed a Helmholtz Resonator. It's engineered to absorb air resonance and reduce sound levels.
The white tube creates a low pressure venturi effect, similar to the function of a carburetor throat.
http://www.phys.unsw.edu.au/~jw/Helmholtz.html
http://www.audioholics.com/techtips/...orabsorber.php
Old 07 Apr 2006, 07:22 pm
Remove that black tube on the side of the airbox and you'll definitely notice some sound and a bit more performance then.
Old 01 May 2006, 04:42 pm
I disagree with chromedcruiser on removing the intake for the air box, sure you might get more sound but performance might actually be decreased. The tube is there to take air from the fender well and not the engine bay, by removing it you are allowing the intake to suck in that engine bay hot air thus decreasing performance. Sound yes I assume it is slightly more aggressive but performance gains, maybe the opposite.
2003 Silver GT Auto Stick
MODS:dual ram-air hood, flames, carbon fiber interior kit,dvd nav tv tuner 7\"touchscreen, Fosgate 4 channel amp, 12\" dual subs with LED box, mb-quart modual speakers, windshild visor, leather racing seats, Goldline springs 3\"drop, Tokico shocks, BOV, C.F. tail lights, and more. Need to install xeon side skirts, rocker pod guages.
Old 02 May 2006, 10:37 am
I have to agree with hotrod
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 03 May 2006, 02:37 am
I'm gonna have to disagree with ya. I did notice more gains from removing the black silencer. You're greatly increasing the ability of the intake to pull in more air by removing the black pipe, cool air is still going to make it into the airbox, it's just going to be mixed with a bit of the warm air from the engine bay. Instead of funneling just a bit of cool air, you're pulling in a larger amount of warm air. What may be a better way is to cut a larger hole into the intake-box and use a 90 or 45 degree piece of 3-4" PVC to direct air in, that would give the best of both worlds.
Old 03 May 2006, 03:23 am
The gain you noticed was from your butt dyno and butt dyno's are all in the head. I agree with Hotrod. Sucking hot engine air is not a good thing. On a dyno a PT GT lost a bunch of torque with an open intake sucking hot engine air. A larger elbow for more cold air intake isn't really going to help a computer controlled n/a PT. You'll increase the noise factor but not performance.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 03 May 2006, 05:35 pm
nice car hotrod !!
Old 03 May 2006, 09:10 pm
mjb457's Avatar
[8)]So after reading this post thee probably isnt any benifit to aupgraded air filter either Airaid or K & N because the factory stock box is best... Correct? Torue wise which is actual power is better with stock??? [)]
remove silencer steve smith Stage Turbo Kits 12 06 Sep 2007 02:27 am
"Reengineered" silencer Espresso Tech & Performance Forum 9 04 Jul 2005 02:21 pm
Silencer Removal andym Tech & Performance Forum 8 18 Mar 2005 03:50 pm
Silencer westsidesd13 Tech & Performance Forum 34 23 Jan 2005 12:55 pm
Air Silencer CHROMEDCRUISER Tech & Performance Forum 17 06 Sep 2004 04:17 pm
