Flow Master Duels
  #11 (permalink)
Old 14 May 2006, 11:45 pm
I just got back form a ride and the noise inside is a bit too much for me in gentle acceleration. This is interior noise; I drove down a city I street with buildings on both sides to it listen to the n echo noise and it was wonderful. Turned a few youngsters heads as well.
When you stomp on it you do not hear a thing. Also the time lag from the turbo pushing air the engine and the air in the exhaust catching up with the flow is just gone. It used to take about 3 seconds for the turbo now it just leaps up and goes. I even felt the front end lifting up and that has never happened.
These are great. Top is all off with 2 chrome oval tips in the rear and it makes for a wonderful package.
2005 Inferno Red Limited seeing way too much fun on the road ahead.
  #12 (permalink)
Old 15 May 2006, 02:30 pm
CHIP, I would way a few hundred miles and let the muffler "break-in" a little bit. I noticed that after about 500 miles of driving with it, the interior noise dimished a bit, and the sound sort of smoothed out. Something to consider before you put a resonator on.
  #13 (permalink)
Old 15 May 2006, 03:01 pm
Chromed - On my N/A 2001, I have the airaide intake, and also put JBA headers on last year. You can say that I am working my way from the front to the back.
  #14 (permalink)
Old 15 May 2006, 05:02 pm
You are definitely going to notice a difference then. I would go to your local reputable muffler shop, and have them custom build you a setup, you will probably save a few bucks and get what you want, and get it welded, not clamped.
  #15 (permalink)
Old 15 May 2006, 05:25 pm
What kind of difference is between welding and the factory clamps? I have noticed that the stock exhaust is clamped.
  #16 (permalink)
Old 15 May 2006, 09:37 pm
Welds just make for a tighter more secure fit... you don't have to worry about a clamp coming loose.
  #17 (permalink)
Old 15 May 2006, 10:23 pm
Chromedcruiser, thanks for the advice. It will be several weeks before I can even think about getting it back in the shop so several hundred miles can easily be put on before we make the final decision. I drove it today in an underground garage and the sound was wonderful. Lots of heads were looking for the source and big smiles when they saw it was a cruiser.
  #18 (permalink)
Old 16 May 2006, 12:14 am
I absolutely love running through a crowd of ricers and just letting off the clutch and gracing them with that flowmaster sound. If you have the 5 speed, I would run it up a bit, and then just let off the gas, allow the "pop pop pop" to go through and let the revs fall, I think that helps with the break-in as well. If you've got the tiptronic, I'm not sure how well that would work. It should mellow though in a few hundred miles.
  #19 (permalink)
Old 21 May 2006, 11:42 am
Went to a shop yesterday and had the PT put on a dyno. Very interesting to hear the Flowmasters wind up to full throttle.
I was with a Mustang club and the little PT just did not sound like a Shelby wound out but it did turn a few heads since it certainly did not sound "riecey." By way, 154 hp at the wheels with the turbo lite, K&N drop in filter and the FLowmasters. The folks at the shop said the Stage 1 is the thing to do next to increase horsepower. The chart showed a nice even hp curve up with max torque at about 4200 rpm.
  #20 (permalink)
Old 21 May 2006, 03:07 pm
Oh, you definitely want to do Stage 1. That is almost a must when you buy the turbo.
Update on Flow Back Catch Can littleblueGT Turbo Performance 3 12 Sep 2006 09:29 pm
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
S&B HIGH FLOW AIR SYSTEM??? bigpoppacat Tech & Performance Forum 5 07 Sep 2005 01:28 pm
Flow back catch can littleblueGT General Turbo Discussions 16 30 Jul 2005 10:46 pm
Exhuast flow one sided turbomangt Turbo Performance 6 20 Feb 2004 03:05 am
