Flow Master Duels
  #21 (permalink)
Old 23 May 2006, 05:28 pm
Do you ever think that I could get my N/A PT up to that power?
  #22 (permalink)
Old 24 May 2006, 01:45 am
It'd take a lot of work. Intake, full 2.5" exhaust, GT intake manifold, bored throttle body, motor mounts, wires, plugs, underdrive pulley, cams, port and polish, new internals probably. If you have an auto, you'd need to get the upgraded power demon trans. Or if you want to make it easy, hook up the bottle and call it a day.
The N/A can make a nice little bit of power, but is not gonna be able to even come close to the upgrade-ability that the turbo has.
  #23 (permalink)
Old 31 May 2006, 12:46 am
Just thought I would provide an update. Went in today and had a resonator installed just forward of the Flowmaster muffler. Big difference in the interior noise. Before a drone that ground the back of your teeth together at gentle throttle pressure. Now just a rumble that sounds like pure music.
The job took all of 15 minutes as the pipe was cut and the resonator welded in place. I highly recommend this set up for folks wanting to increase performance, noise, and throttle response. A winning set up.
2005 Inferno Red Limited seeing way too much fun on the road ahead.
Update on Flow Back Catch Can littleblueGT Turbo Performance 3 12 Sep 2006 09:29 pm
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
S&B HIGH FLOW AIR SYSTEM??? bigpoppacat Tech & Performance Forum 5 07 Sep 2005 01:28 pm
Flow back catch can littleblueGT General Turbo Discussions 16 30 Jul 2005 10:46 pm
Exhuast flow one sided turbomangt Turbo Performance 6 20 Feb 2004 03:05 am
