trans ?
Old 06 Jun 2006, 11:16 pm
Send a message via AIM to ptTurbo528
Default trans ?
i want to R+R my trans filter and fluid is there anything that i need to look out for or be aware of when i do this? Is a fram filter ok for this or is there another brand i should consider? Just need to know if there is anything speacial i need to know or do?
Old 27 Jun 2006, 07:29 pm
You should really have the entire system flushed. A portion of the old fluid will still be in the torque convertor. Then you end up mixing old fluid with new fluid. Only use ATF+4. Sorry I don't have more helpfull info for you.
Good luck[^]
Old 27 Jun 2006, 10:05 pm
Does Fram really make a transaxle filter for the PT? I'd stick with an OEM filter if I were you. Chrysler's trans is a weak point to begin with, no sence using an off brand in there. Also, OurPTGT is right about doing the full flush. It will costs more becuase I don't think you can do it yourself, but well worth the cost.
Old 28 Jun 2006, 05:24 pm
have the whole tranny flushed out, its the best thing you can do, and you cant do it yourself at least not without taking the whole tranny out
Old 28 Jun 2006, 11:19 pm
Hey thanks guys for the info..i guess ill take it to the dealer and have them flush the system out. I knew that if i did it myself that i would have some residual fluid left in the trans but i figured it would be better than nothing...Thanks guys.
03 gt painted steel blue,
goldline coil springs custom exhaust done by yours truly..k&n typhoon intake..tinted windows member of ptcruiserclub.org..adjusted wasetgate. E&G classic billet grille. 600w alpine amp,2-twelve alpine typeR subs,alpine headunit.xeon headlights,fog lights.apc carbon fiber taillights. royal purple oil. k&n oil filter,mopar bov conversion,BTG strut tower brace....
Old 29 Jun 2006, 09:48 pm
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
I know i say it over and over again, but i am SO glad we opted for the manual transmission. With that said, i remember taking our dodge caravan and having that done. it cost us $100.00
GT with automatic trans and gas mileage coopj40 General Turbo Discussions 10 22 Apr 2005 04:10 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
Estimate on better rods, pistons, beefier trans... crazie.eddie Tech & Performance Forum 5 04 Dec 2004 12:33 pm
Shocks/Struts and Trans Fluid 1lowufo Tech & Performance Forum 3 04 Nov 2004 02:15 pm
Stall Speed Autostick Trans FRM3 General Turbo Discussions 12 11 Jan 2004 03:59 pm
