PT Cruiser Forum Car Videos
Car Rims
How to do spark plug wires?
  #11 (permalink)
Old 08 Jul 2006, 04:02 am
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
Well i think i am going to pick up the magnacores. A good price and recommended by you all. But what plugs do you think I should get?
2005 Linen Gold 5spd
PT Cruiser Links Moderator
  #12 (permalink)
Old 08 Jul 2006, 08:34 am
CREWZIN CREWZIN is offline
For the Non-Turbo, almost everyone agrees with the Champion Double Platinum #7570 gapped at .042in They fit right and last a long time. Also for a better job, use Dielectric greese on the plug wire ends and Anti-Seize on the threads of the plugs.
  #13 (permalink)
Old 08 Jul 2006, 02:15 pm
CHROMEDCRUISER CHROMEDCRUISER is offline
Go with the Crane Firewires. Best bang for the buck, better than Magnacores, 8.5mm, less resistance (25 ohms per foot), and extremely reliable. I would suggest going with Bosch platinum plugs.
The dealer is probably gonna charge $100 or so for the install. But if you sneak out to the garage one night and pop the intake manifold off, you can be done in about 20 minutes.
  #14 (permalink)
Old 08 Jul 2006, 02:16 pm
http://www.raceandstreet.net/Merchan...ategory_Code=P
  #15 (permalink)
Old 10 Jul 2006, 05:07 am
thegoldpt's Avatar
Yeah them cranes are a good deal. I may go with those and the champions. Thanks for all you help..
(I have snuck out into the garage to install many pt accessories.) But i figured out i dont have the tools for the job.
  #16 (permalink)
Old 15 Jul 2006, 11:56 pm
fritz_t_coyote fritz_t_coyote is offline
The Tools Issue:
Especially the NA PT with the tricky plastic manifold. I had to buy a fancy new torque wrench to change the plugs, because while my old torque wrench was fine for old V-8s, shovelhead V-Twins, or the tractor motors of old Triumphs, it is pretty vague anywhere under 25 ft/lb, making it (as Zathrus would say) "The Wrong Tool".
You might want to find an non-dealer local mechanic to do the job for you with you specifying the parts.
Also: As for the 'should i bring the parts' ... would you bring a couple of raw eggs to a diner and ask them to fry them for you? If you are thinking of doing this make sure you got it worked out with the mechanic first.
www.visualizecommonsense.com
  #17 (permalink)
Old 24 Jul 2006, 08:30 pm
PTRobert PTRobert is offline
If you do them yourself, there are two (I believe) bolts on the back of the throttle body mount that have to be removed. I forgot about these when I did my plugs & wires last time and I broke the metal mount. I had to buy another; thank goodness it was only a $25 part.
I vote to stay away from double-platinum or even platinum plugs and don't waste your money on fancy wires.
My first change of plugs and wires was expensive ($150) for parts alone. I installed blue magencor wires and Champion double platinum plugs. My PT hated those parts. Within 6 months the wires and plugs had failed; the plugs had gone rotten and ruined the wires completely despite installation with the proper dielectric grease, etc. I went back to a stock setup and all my problems disappeared. This was about 18 months ago.
If you're going to upgrade your plug wires, stick w/ Mopar (IMO) since they're made for the car and engine.
2003 Classic Edition, 5-speed with 7-ball shift knob, badges removed, dark tint, Borla split exit exhaust, short billett antenna, Nu-Image white-faced blue flamed gauges and 15\" American Racing Aero Wheels.
  #18 (permalink)
Old 25 Jul 2006, 07:44 am
rszappa1 rszappa1 is offline
Isnt it funny how sometimes the stuff that came with the car turns out to be the best....I had the same problems with the Iriduim Plugs...Had a miss and the stock factory plugs worked fine...
  #19 (permalink)
Old 15 Jun 2007, 02:42 pm
kprawdzik kprawdzik is offline
Default Re: How to do spark plug wires?
When you put the intake manifold back on should you stagger the bolts when tightening, and what should you torque them to?
  #20 (permalink)
Old 16 Jun 2007, 01:33 pm
Hooligan Hooligan is offline
105 inch lbs.
2008 Silver Steel Metallic, Touring, NA, Sirius; chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals.
vB code is On
Spark Plug Wires thegoldpt Tech & Performance Forum 22 24 Dec 2007 11:08 am
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
PERFORMANCE SPARK PLUG WIRES RODRUN Turbo Performance 1 03 Jul 2003 11:20 pm
  Vegas Hotel | American Flags | Internet Advertising | Credit Cards UK | Remortgage
