PT Cruiser Forum Car Videos
Custom Wheels
Rear Drum Brakes
Old 03 Oct 2006, 04:30 pm
rszappa1 rszappa1 is offline
Default Rear Drum Brakes
It is well known that the rear drum make noise....I have heard that it is the shoe material causing it and I also have heard that it is the cheap steel used in the drum that is causing the noise....Has anybody found a solution to the problem????...Besides cleaning the dust out every month or so....
Old 03 Oct 2006, 08:12 pm
bobs turbo pt bobs turbo pt is offline
could it be converted to disc ?? or too much work and money ??
Old 03 Oct 2006, 09:56 pm
Way too much money....
Old 03 Oct 2006, 11:22 pm
is there a better aftermarket drum ??
Old 03 Oct 2006, 11:35 pm
I read on one site that theproblem is the cheap steel they are using for the drums...But I want to be sure before I replace them that ...that is the problem and not the shoes....
Old 04 Oct 2006, 11:28 am
black_gt_boosty_hh1321 black_gt_boosty_hh1321 is offline
keep an eye on your local pick n pull. If you can get the parts from there, it's not cost prohibitive at all. I'd go with new discs and pads, but the hardware will be fine, and the calipers should be fine, and if not, rebuildable. Other than that, I don't definitively know the answer to your original question, but I would look to the shoes first (cheapest part to start with). Make sure all the hardware is exactly where it needs to be as well. Good luck...
vB code is On
rear brakes robin Wheels, Tires, Suspension 2 19 Mar 2007 09:13 am
REAR DRUM BRAKE TO DISC UPGRADE blue General PT Cruiser Discussions 18 04 May 2005 09:51 am
UPDATING REAR DRUM BRAKES TO DISC blue Tech & Performance Forum 5 14 Apr 2005 12:01 am
Rear drum to disc conversion. Can this be done? snakepitt1 Tech & Performance Forum 6 15 Jul 2004 03:09 pm
Complete Rear Suspension with Drum Brakes yellowpanel Classifieds: For Sale/Trade 0 09 Aug 2003 01:37 pm
  Deals On Products | Tutorials | Mortgages | Satellite TV for PC | Agencia de viagens
