Darn
Old 18 Oct 2006, 02:45 am
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
Default Darn
Well, for the first time in it's life, I have to take the cruiser in, It has this "tick" sound that goes with the RPM of the engine. It also has a very rough idle like when you are letting the clutch out to fast, it dips down and then shoots back up. I am now running over to race and street to get those plugs and wires bookmarked. NO WAY am I letting them put those
wires back on my car. [?][xx(]
Old 18 Oct 2006, 03:29 am
Good thinking.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 18 Oct 2006, 09:35 am
How many miles? My wires started to go on my '05 before 20,000 miles!
Plugs & wires can never hurt, but only way they'll cause noise is if wires are arcing and you could hear it, which I suspect would give you a misfire error code.
Read this tech bulletin:
09-007-04 03/02/2004 Engine & Engine Cooling:Engine -
Irregular Engine Snapping Sound
OVERVIEW: This bulletin involves chamfering the bore
radius on cam bearing caps L2 through L5 and R2 through R5.
NOTE: This bulletin applies to vehicles equipped with a
2.0L, 2.4L DOHC, or 2.4L Turbo engine (sales code ECC,
EDZ, ED1, EDV, ED2, or EDT).
SYMPTOM/CONDITION: The sound may be noticed when the
engine is idling in park between idle rpm and 1400 rpm at
normal operating temperature. The sound is on the upper
end of the engine (cylinder head) towards the front of the
engine or passenger side (right side). The sound is
irregular, not periodic or harmonious. The frequency of
the sound will increase with RPM. The sound is more of a
higher pitch snapping noise, not a low metallic knock.
Old 19 Oct 2006, 01:32 am
thegoldpt's Avatar
Sounds Like it to me, well they are going to tell me monday what the final prediction is.
2005 Linen Gold 5spd
PT Cruiser Links Moderator
Old 19 Oct 2006, 01:35 am
thegoldpt's Avatar
18,020 miles right now
Old 05 Nov 2006, 12:39 am
what was the problem ??[:I]
Old 06 Nov 2006, 07:54 pm
thegoldpt's Avatar
Ah I never got around to taking it in. They ran some checks when I took it in for it's little oil change, they said it's fine. To me, it always sounds better after an oil change. If any thing develops, I will post it up.
Old 08 Nov 2006, 01:20 am
is it still ticking ??
Old 11 Nov 2006, 02:15 am
Hope you get things fixed, good luck.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
That Darn Hum turboinferno Tech & Performance Forum 7 10 Nov 2006 10:13 am
Darn, they'll race anything nowadays. CREWZIN Non-PT Discussions 3 17 Apr 2006 03:38 pm
DANG...DARN...SHOOT...scratched my car...HELP Cal Cruzer The Detail Shop 3 09 Mar 2005 10:51 pm
Does anybody work there? sabishop Exterior & Interior Styling 27 26 Mar 2004 04:03 am
Argh...darn these pics of the Block Party sakigt General Turbo Discussions 5 26 Nov 2003 06:00 pm
  Free Music Download | Acs Student Loans | Wordpress Themes | Anime | Find jobs
