anybody fixed this problem?
Old 24 Oct 2006, 12:51 pm
Default anybody fixed this problem?
on my 03 GT when I accelerate moderate to heavy I can feel air coming in thru the dash vents because vaccum is low and allows the vents to open.....anyone installed a check valve in the vaccum lines? if so where
Old 24 Oct 2006, 03:19 pm
I haven't heard of that problem, and I'm on other PT forums - one where there are lots of modded turbos.
Sure you don't have a vacuum leak?[:I]
Old 24 Oct 2006, 04:31 pm
never had that happen either ??[:I]
Old 24 Oct 2006, 06:07 pm
News to me. [:I]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 24 Oct 2006, 06:09 pm
if I had a vaccum leak more than likely I should have a high idle and if i had a vaccum leak the air would come thru the vents all the time-same thing as accelerating.....no vaccum
Old 24 Oct 2006, 11:48 pm
Try turning the selector to recirculation instead of fresh air. I've noticed when the windows are cracked or sunroof is open, I get airflow through the vents as well, because it is on the fresh air setting!
Old 25 Oct 2006, 12:03 pm
I keep the selector on recirc all the time, thats how I know air is coming out of the vents when it shouldn't be
Old 25 Oct 2006, 12:09 pm
Well, then, I'm pretty sure that's a mechanical selector, not vacuum. maybe a broken cable?
Old 25 Oct 2006, 05:00 pm
it's vaccum because the air only comes out of the vents on moderate to hard acceleration, otherwise if it was a broken cable I would have air all the time. can someone with a turbo try theirs and let me know
Old 25 Oct 2006, 07:55 pm
I'm the 4th GT owner that has replied to you. Mine doesn't do it either [:I]
Fixed timing belt now another problem EvilWRX Tech & Performance Forum 1 13 Feb 2007 09:35 am
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Bumper problem fixed stirfry General PT Cruiser Discussions 18 24 May 2004 04:02 pm
APC tails condensation problem fixed coopj40 General PT Cruiser Discussions 5 01 Apr 2004 08:33 pm
