STRANGE NOISE WHEN STARTING>>>
Old 03 Jan 2007, 10:03 pm
mjb457's Avatar
Default STRANGE NOISE WHEN STARTING>>>
[:I]My PT gives a hiss or kind of puff from the engine area when starting.Almost sounds like a air starter leak.I origionally thought it was a squeak from belt but very different,, any ideas from others with possible same situation in the past. Car runs fine. I even thought it almost sounded like a compression leak but who knows. Ill await your opinion before I take it in.Thanks MJB[8)]
Old 04 Jan 2007, 10:03 am
Check that the black plastic/rubber intake hose is clamped tight, and air cleaner box is clamped down. I'm guessing intake noise.
Old 11 Jan 2007, 04:38 pm
mjb457's Avatar
[:I]Hi na I dont think thats it,,I did check clamps and all ok again thanks...BELTS?? Are Pt's prone to belt noise???[:I]
Old 12 Jan 2007, 01:31 pm
No more than any other car.
Without more clues, kinda hard to guess....[:I]
Old 22 Jan 2007, 10:59 pm
mjb457's Avatar
[8D]Its fixed to the tune of $50.00 allternator belt tentioner needed tightning..** alot of little things with these cars...should I buy a TDI VW? [:I][8)] alot better MPG!!! 45MPG at least!!
Old 23 Jan 2007, 11:54 am
In my experience, if a belt's been slipping, it gets a glaze on it and it's best to replace it. Hope you have a permanent cure in your case.
As to the TDi - I doubt 45 mpg - and look at diesel prices - in NJ, diesel costs more than high test, so you BETTER get a LOT better mileage to just break even.
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Strange noise from front of car xyster Tech & Performance Forum 8 15 Dec 2005 08:53 pm
Turbo noise sawdust123 General Turbo Discussions 19 28 Mar 2005 01:35 am
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
