noise from frontend
Old 13 Jan 2007, 09:37 pm
Default noise from frontend
Have a few symptoms. One a popping noise that I can feel in the wheel while turning left while at slow speeds. Also if I quikly accelerate and turn the wheel same direction. Along with that I am hearing what sounds like a rubbing noise (similar to mud tires) at any speed. Can slightly feel it in the wheel but goes away when I'm taking a curve to I think the left, haven't driven it in two weeks. I can also hear a faint grinding noise from the passenger side whith very slight pressure to the break. I rotated the tires to see if it was a front tire and noticed my passenger tire was warn in the middle and inner inside aspect of the factory tires. I have had no drag or pulling to one side that I've felt. It is lowered but allignment is suppost to be correct. Anyone have a clue, say in a search something similar but not getting all of it. CV for maybe the popping but shouldn't that continue to get worse and pop more than just once at a spacific spot?
Old 15 Jan 2007, 06:32 pm
c v joint ??[:I]
Old 22 Jan 2007, 10:55 pm
mjb457's Avatar
Ok My PT,'03 with 44500 mile was just in for inspection(PA) anyway everything passed but mechanic mentioned Right Front wheel bearing is loose(wearing)..which may be what you are experiencing..& needs replacing soon..$350.+ allighnment $89.00(OUCH) anyway anyone have experience with this?? Common? Advise...thanks,,, MJB[:I]
Old 23 Jan 2007, 12:12 pm
SOme have lost wheel bearings - that would be a rubbing or groaning sound, but I don't think a popping sound.
I'd get another estimate - $350 for a wheel bearing sounds high.
Old 24 Jan 2007, 09:49 pm
Balljoint?
Old 25 Jan 2007, 12:06 pm
did you ever fiqure out whats making the sound ??
Old 02 Feb 2010, 02:21 pm
Roddyh0t22crd's Avatar
Default Re: noise from frontend
I'm getting the same problem with the tyre noise, not the other problem.
It sounds like grinding or bad tyre slap and it's pretty loud at anything over 40mph.
The only way to get rid of it is to veer to the left or brake hard. I was thinking it might have something to do with the suspension as it does seem to go whenever force is put on the front right tyre.
The front tyres are reasonably new but they are Goodyear. Treads are ok but I did notice a couple of cracks on the side. The older tyres on the back are much further worn down and due to be replaced, so going to be expensive to replace all four. I need to change the alloys too due to air leaking from rusting.
The car itself is a 2002 2.2 CRD with 90K on the clock. Not a bad mover but not getting much more than 40mpg.
Old 02 Feb 2010, 02:36 pm
Welcome to the forum.
Where ar you? UK?
Jack car up and see if there is "play" when you grasp the wheel - not the sttering wheel, the right drive wheel - that's test for wheel bearing.
Look at the drive axles - are the rubber boots torn?
Old 02 Feb 2010, 03:15 pm
Hi,
Yes, I'm in the UK, I stay in Fife, driving through to Glasgow everyday so noise is pressing concern.
Will check the wheel out tomorrow. Seems like a lot of folk had problem with bearings.
thanks
Rod
Old 19 Mar 2010, 06:39 pm
For an update if anybody has the same problem, it was the front wheel bearings causing the noise.
I've had both front hub bearings replaced which sorted the problem out. Car's well quiet in comparison now.
Wasn't cheap though at about 160GBP per side, mechanic had a bit of trouble with the first bearing but didn't take so long 2nd time.
Noticed the play when I wobbled the wheels by hand. Didn't need to jack the car up. Can't feel them wobbling now.
I've read the make's prone to the bearings wearing as it's a heavy front wheel drive. Muckle mercedes engine doesn't help.
Changed the alloys too to sort the air leakage out, got a set of Fox R3's which don't look so bad. Been an expensive couple of months.
Cheers
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Turbo noise sawdust123 General Turbo Discussions 19 28 Mar 2005 01:35 am
after recall repair: new rubbing noise otrqt Tech & Performance Forum 2 16 Jan 2005 11:32 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
