Flushing Radiator
Old 06 Feb 2007, 04:17 pm
Default Flushing Radiator
Should this be done at home or should I just let Chrysler do it?
Thought from those who know more about it then me.
Thanks
Old 07 Feb 2007, 12:03 pm
It is easy enough to do at home BUT... there is the problem of disposing of the used coolant.
It is considered hazmat, so you can't just dump it down the storm drain.
So you can pay a dealer a lot to do it, or use an independent garage, which can save you money and hassle.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 07 Feb 2007, 12:40 pm
Fritz,
Thanks, actually I stumbled upon this in my Haynes Manual late last night, I couldn't find it previously. Seems like something I can't mess up too much, so I will give it a try this weekend.
Show work out with a garden hose because I shouldn't have any sedement, the coolant looks pretty good to me, but does need to be changed. Since I'm taking it apart anyways, might just drain it too and flush it when fixing the thermostat.
My thermostat is defiantly done for, the PT hardly reads warm at all now, so that tells me that it is stuck open. I'm trying hard not to drive to hard until sat.
Its nice, Walmart takes junk you leave out and gets rid of it for you. Thats what I call disposal, let them deal with it. That's what I did with my battery when they wanted me to wait two hours to change it, I said I'd leave it outside, they said ok, we'll take care of it.
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
Old 07 Feb 2007, 06:05 pm
That's funny, usually the stat will fail closed unless you buy a special aftermarket one that states it fails open ( I can't remember the brand), and at the time I didn't see one that would fit the PT.You may have a temp sensor that is going bad.
Old 08 Feb 2007, 08:27 am
See I knew it would be down hill from 60,000k.
Kingkole02
Old 10 Feb 2007, 11:27 am
I do my own oil and coolant changes and I know that the local Pep Boys has an area to drop your used fliuds off free of charge,any time of day, which is handy for me,because as a third shift worker,I do alot of my work in the early am hours when shops are closed.
Old 13 Feb 2007, 08:36 am
I finally did the job last night. Was surprised the coolant didn't look too bad. However the thermostat was broken in two pieces. So I'm glad I learned something from it all.
Still have the check engine light and same fault code. Guess it needs to be reset. [:I]
Kingkole02
Old 13 Feb 2007, 12:02 pm
Pep Boys takes oil & coolant also here in new york
Old 13 Feb 2007, 03:24 pm
I plan to make a drop off at one of those shops tonight to rid myself of my old coolant.
The light reset itself this mourning as I drove on my lunch break.
Kingkole02
Old 13 Feb 2007, 04:08 pm
Great news Colby, now get to cleanin up that garage.
Petcock on radiator gonzomania General PT Cruiser Discussions 4 23 Aug 2008 01:07 pm
Radiator cap's life span LoboMX Turbo Performance 10 03 Apr 2007 11:08 am
Radiator not pulling from reserve Hotrod General PT Cruiser Discussions 5 19 Oct 2005 09:07 pm
Upper radiator hose Group buy OurPTGT General Turbo Discussions 3 20 Sep 2004 07:35 pm
Radiator fluid change? stirfry General PT Cruiser Discussions 2 03 May 2004 04:45 pm
