PT Cruiser Forum Car Videos
Custom Wheels
Latest on the transmission
  #11 (permalink)
Old 07 Mar 2007, 07:05 pm
fritz_t_coyote fritz_t_coyote is offline
OK, so the 06 has that dumb electric trunk latch,
and a bad manual tranny.
Sigh.
Guess I'll just hang onto my 02 for a few more years.
www.visualizecommonsense.com
  #12 (permalink)
Old 20 Apr 2007, 07:04 am
kutzner kutzner is offline
Default Re: Latest on the transmission
Hi Im new on this Forum - great to have so many brains out there to pick
Ive got a 202 PT Woody and ony 45K miles and the Tranny packd up - dealer says no oil pressure in Torque Convertor - wants $4000.- for reconditioned. Warranty expired
What would interest me is this Tranny a major problem with the PT
Do you think it would be worth talking to Chrysler direct
Thanks for any input
Andy
  #13 (permalink)
Old 20 Apr 2007, 08:52 am
umaxman umaxman is offline
If it is an automatic then yes they are a problem and it won't do any good to go to Chrysler as they don't give a crap about them or you after you buy them.
My tranny went also in my 02 and I had it completely rebuilt and it was no were near $4000, so I would look around and check out some other places.
Chrysler has some problems but they don't like to stand up and admit it or do anything about them, and what gets me is they just keep using the same defective parts over and over..
Other than that I love my PT.....
  #14 (permalink)
Old 20 Apr 2007, 01:58 pm
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
Originally Posted by JOEMAMA View Post
Check out my signature for my vehicle specs...
Heres the bottom line...
Since I bought my PT in September 2006, I have taken it into the dealership three times for a clattering noise coming from the driver's side of the engine (same side tranny is). The noise is only present in cold temperatures and the noise goes away either when you depress the clutch, or when the vehicle reaches full operating temperature.
1ST Visit - dealer replaced clutch and bearing assembly - did not fix.
2ND Visit - dealer replaced input bearing - did not fix.
3RD Visit (yesterday) - dealer contacted engineering in Windsor, ON (Canadian tech centre). Engineering stated they are aware of the problem, but at this time there is currently no remedy for the condition. Apparantly, this is a common problem and attempts at replacing the transmission have resulted in the same noise. Engineering has confirmed the problem to be in the tranny itself, but they have no fix.
UPDATE!!!
The tranny in the 2006 m/y is a "world transmission" according to the service mananger at my local dealer. He himself has stated this noise is not normal. He said DCX Engineering stated the problem lies with a rattling gear synchro (ring) between 2nd the 3rd gear when no load is present. At this point nobody knows if this will affect the longevity of the transmission.
Sounds a lot like your problem thegoldpt......what were your symptoms?
Well my transmission was only hard to shift and would grind. There was no ratteling noise. What they need to do is drop in a new transmission and see if that fixes it
2005 Linen Gold 5spd
PT Cruiser Links Moderator
  #15 (permalink)
Old 22 Apr 2007, 10:03 am
bobs turbo pt bobs turbo pt is offline
no way !! shop around !! "wants $4000.- for reconditioned"
vB code is On
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 4 06 Jan 2006 07:12 pm
transmission lotta Tech & Performance Forum 6 29 Sep 2005 08:44 pm
Transmission Went Mean Green General PT Cruiser Discussions 8 16 Oct 2004 11:49 am
Transmission fliud - B&M Trick Shift or not? snakepitt1 Tech & Performance Forum 8 22 May 2004 06:58 pm
"Internal Transmission Problem" ??? yobiebs General Turbo Discussions 18 21 Oct 2003 11:17 pm
  Personal Loans | Pink Ranger | Debt Consolidation | Myspace Layouts | Loans
