Rough Idle on 2003 Pt- Not plugs and wires
Old 12 Mar 2007, 09:34 pm
Default Rough Idle on 2003 Pt- Not plugs and wires
I know this has been covered in the past but my problem seems different. I have changed plugs and wires with no change. I get no error codes on my EBDII reader. I did notice that the problem seems worse with the heater or air conditioner on when the cooling fan starts. Also the O2 sensor output is a sine wave when it is running smoothly but the wave form distorts when the engine stumbles. I don't know if the O2 sensor is just reporting what is happening or is the cause of the problem. Also when the idle is held above 1000rpm it does not stumble. I am thinking it may be the coil or the O2 sensor. Any help would be appreciated.
Thanks,
Jim
Old 13 Mar 2007, 08:09 am
Here's a long read, but might be your problem:
http://ptenthusiasts.org/forum/showt...highlight=idle
and another one:
http://ptenthusiasts.org/forum/showt...&highlight=IAC
since you mention it's worse with A/C, might be the IAC.
Old 13 Mar 2007, 04:03 pm
I was out to check and the stumbling problem is not related to the heater or A/C systems. It starts to stumble when the cooling fan starts and continues as long as it is running. I will try the WD-40 trick tonight after work.
Jim
Old 14 Mar 2007, 08:47 am
Good luck, and keep us posted.
Old 14 Mar 2007, 11:10 am
welcome to the board !! good luck !!
Old 26 Mar 2007, 10:26 pm
I read something similar on another site and they stated that it sounded like the EGR Solenoid/Valve. You may want to check that.
Old 27 Mar 2007, 09:22 am
hey jim, did you fiqure out the problem ??
New Plugs & Wires ? BB General Turbo Discussions 5 09 Jan 2007 12:37 am
Installing spark plugs and wires hangtym3 General Turbo Discussions 11 18 Sep 2005 12:41 am
Just changed plugs & wires gonzomania Tech & Performance Forum 2 04 Aug 2005 05:13 pm
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
Plugs & Wires BACKinMOTION Tech & Performance Forum 4 11 Jan 2004 01:36 am
