IÂ’ll try to make this as short as possible Â… but something is up with my Â’03 Turbo that doesnÂ’t make sense. My A/C stopped working today, so I open the hood to check the fuses and relay and they work fine. (I used the brake light relay). What I noticed though, is that there is NO high speed or low speed engine cooling fan relays in the fuse box! The 40 amp fuse is also missing!
Last Oct … thanks to help/info from this forum, I thought I had an Auto-stick tranny problem that ended up being motor mounts. I had them repaired at a local lube and tune. It is the first time I ever left the car at a shop and not stayed and watched the work being done. (I met the owner through a friend). I cannot think of any place else that has been under the hood (without me present). Since I found these missing relays and fuse, I’ve read the owners manual “fuse box” and engine cooling sections … looked at the A/C and engine cooling fan sections of the 2003 PT Cruiser Service Manual Disc I bought online … and read through all of this forum’s A/C posts and I’m still lost. [:I] My questions are … the weather has recently been pretty hot here, (80+ degrees), but I have used the A/C (which has worked), since the repair … could the missing relays and fuse cause the problem? AND … does anyone know of an honest A/C, (and/or repair shop for future reference), in the South Bay of Southern California? I live in Redondo Beach. |
The cooling fan is a variable speed fan, controlled entirely by the PCM. The high & low speed relays have been elliminated.
Thanks for the info ... the owner's manual looks like that there should be low and high speed relays and a 14A fuse. I did notice that when I pulled the tail light relay (to insert in the A/C relay to see if the A/C relay was bad), the input contacts for the high and low speed relays were not shiny like the tail light contacts. I'll take it to an A/C shop. Anyone know of a good one in the Los Angeles area?
'03 PT Turbo, Auto-Stick, Steel Blue Paint, Factory Roof Racks w/ Custom Deflector, Light Blue Driving Light Lenses, AOOGAH Horn, Kumho ECSTA ASA- 205/50R-17 M/S |
The A/C on my 04 stopped working, so I went to the dealer. Turned out it blew a hose. They did it under warranty, no problems. You may not have that option. Turn on the A/C and see if the clutch operates. If it doesn't, the PCM is seeing something that says don't, or the PCM can't turn it on due to the clutch circuit. Any competent A/C shop should be able to handle it.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
I've got an '02 non-turbo, and the A/C just stopped a few weeks ago. How do you know if the clutch is working or not to test?
Thanks. |
I checked all fuses and they are okay, I swithched out the relay's and the A/C still does not work. I cannot hear any clutch kick in when I turn the A/C on. Would the next logical step be to just take it in and have a shop test everything? |
Yes. Could be as simple as being low on R-132. Either way, they should test it for free.
like crewzin said it may just be low on freon let us know what you find good luck
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
| Engine problem | BORICUA | Tech & Performance Forum | 49 | 03 Apr 2006 05:15 am |
| Complete Engine Swap | TaylorMade | General Turbo Discussions | 35 | 05 Jan 2005 03:34 pm |
| N/A Base Engine vs Turbo Engine | Kirby | General Turbo Discussions | 7 | 02 Oct 2003 01:42 am |
