Timing Belt Replacement Instructions
Old 08 Jun 2003, 02:11 pm
Default Timing Belt Replacement Instructions
I'm approaching 100,000 miles on my 2001 Cruiser and want to replace the timing belt (just to be on the safe side). I've replaced the timing belt myself on every car I've owned over the last 30 years. However, I've read on several forums that this can be tricky on the Cruiser, due to space constraints. Does anybody have a copy of the replacement prodcedure that they could send me (email, fax, snail mail, etc)?
Thanks in advance! [^]
Old 08 Jun 2003, 05:57 pm
PTFever,
I'm sitting here reading the Haynes manual on replacing the timing belt for the 2.4L models. There are two pages of instructions and 11 illustrations and a few cautions...and that's for the removal. The installation is another page and a couple more illustrations. Now SCI-Fi would kill me for suggesting this, but if you really want to do-it-yourself, Get ahold of the Haynes manual Number 25035 for about $20 or the service manual from the dealer for a lot more. Did you try www.ptdoityourself.net ? They might have instructions and photos for the timing belt. [:I]
Old 09 Jun 2003, 12:17 am
You know,
There are many CD-R copies of the OEM manual on E-bay for less than the cost of the Haynes manual.
They are the real Chrysler information.
I suggest buying a real one from Mopar, but some feel that $80 for a manual for a $20,000 car is too high.
You can get them here:
http://store.yahoo.com/wyckoff-chrys...uisfacse1.html
This is only the opinion of a master certified ASE career auto tech.
Old 29 Dec 2009, 02:13 pm
Default Re: Timing Belt Replacement Instructions
We have replaced the timing belt on our 2002 PT and it will start but will not idle. In looking at the diagrams you referenced, it shows that they are not completely straight across but off just 1 click for the 2.4 model. Is that correct or should they be lined up straight across? The photo is not clear in that manual.
Thanks for any help. This is our daughter's car and we need to have it up and running by this weekend when she heads back to college.
Thank you
Linda & Dwayne Smith
Old 29 Dec 2009, 03:15 pm
Dwayne,
You replied to a posting that's 6 1/2 years old. (June of 2003). From what I've heard, didn't do it myself, the gears aren't lined up exactly level before the belt is replaced and it does line up correctly once the belt is put on. Don't know if that will help.
Old 29 Dec 2009, 11:51 pm
I just finished my timing belt and it did not line up exactly. I used the "mirror the belt" technique so it was exact to the original. Also, when I lined up the crankshaft prior to removal, it was off a little, It was the exhaust cam that was different, but I don't remember if it was above or below the reference notch on the intake cam.
Old 18 Jun 2011, 12:05 pm
golf55555's Avatar
So does anyone have the instructions? I know this post is old, just thought I would ask for some help before I tear into the 01 I just bought. The guy I got it from said it had a cracked head.... Just wondering if it may just be the timing belt...
Never know!
Starting the tear down today after work, any help is GREATLY appreciated!!
K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Old 18 Jun 2011, 01:23 pm
Check in the PERFORMANCE section, there should be a number of helps there!!
Timing belt replacement snakepitt1 Tech & Performance Forum 5 08 Nov 2007 05:33 pm
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
timing belt Thomas1 Tech & Performance Forum 17 03 Jun 2004 04:28 pm
Timing belt replacement? mojogator Tech & Performance Forum 3 12 Nov 2003 03:30 pm
