PT Cruiser Forum Car Videos
Custom Wheels
Squeak From Rear of Car
Old 12 Jun 2007, 12:33 pm
funksoulkitty funksoulkitty is offline
Default Squeak From Rear of Car
Hello Everyone, I am new to the forum and I had a quick question. My '03 Cruiser has developed a horribly frustrating squeak from the rear of the car. It started out intermittent but now is constant above 70mph. The timing of the squeak coincides with suspension movement, so I have thoroughly gone through all of the suspension components in the rear. Nothing appeared worn or damaged though.
My boyfriend mentioned that when the rear shocks went bad in his Quantum they squeaked despite not showing typical signs of shock failure. So, I figured after 63,000 miles (3,000 of which was spent towing a 1,500lb trailer) that the rear shocks might be up for replacement. I installed a new set of KYBs and after a test drive on the freeway the sound was initially gone.....only to return a short time later (on the same test drive). While I had the car up on jack stands I checked out the bump stops and noticed that they squeaked a little. I doubt that I would be able to hear that from inside the passenger compartment while driving at 70+mph....but maybe it would be possible.....
Anyhow, I was wondering if anyone had any ideas as to what it might be? Any help would be greatly appreciated
Kirsten
'03 PT Cruiser (Miss PT)
'79 VW Scirocco 1.8T (Shocky Jr.)
http://www.funksoulkitty.org
Old 12 Jun 2007, 03:38 pm
CREWZIN CREWZIN is offline
Default Re: Squeak From Rear of Car
Kirsten,
Only thing I can suggest is to get some WD-40 or other type lubricant and spray everything that moves in the rear. To try and pin-point the exact location, try one side of the car first. Suspension parts, including where the springs seat are your most likely culprits.
Welcome to the forum.
2000 PT. 96K miles, Original Owner
Old 12 Jun 2007, 04:38 pm
Thanks for the input CREWZIN. I did try to grease up all the components down there but I don't believe I got where the springs seat. I will have to put her up on ramps tonight and take a look.
Kirsten
vB code is On
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Rear door sill scuff pads stronda Interior Accessories Forum 5 04 Sep 2003 05:46 pm
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
  Debt Consolidation | Mobile Phones | Used Cars | Remortgages | Mortgages
