Synthetic Oil
Old 17 Jun 2007, 01:39 pm
Default Synthetic Oil
Do You guys think it's a good idea to run synthetic oil in these cruisers, mine is a 2.4 non turbo, or just stick with regular oil at every 3000 miles? And if you guys run synthetic what is a good brand you've found?
2006 Limited, Marine Blue Pearl Coat, Metallic silver pinstripes, front windows tinted to match back, more to come
Old 17 Jun 2007, 02:10 pm
Default Re: Synthetic Oil
I run synthetic oil in every car I have. If you run your cruiser in any kind of extreme conditions (hot or cold) it's a little extra protection. Most reports say you can gain and extra mile or two in gas mileage too. If money is tight, just stick to a dino brand and change every 3K miles as synthetic will run you an extra $20+ at each change.
Old 17 Jun 2007, 02:52 pm
I too run synthetic oil in all my cars. My PT is the HO Turbo. I use Mobil1 oil and their oil filter. What's nice about the Mobil1 is that I double my oil change to every 6000 miles. GM suggests once a year for my Vette.
2005 GT Cruiser, Cool Vanilla, Automatic, Borla Dual Exhausts, K&N, Navigation and U Connect.
2001 Corvette Convertable, Navy Blue Metalic, Z51, 3:15 with 4" inch quad Borla Stinger Exhausts X Pipe and K&N Filter.
Old 18 Jun 2007, 12:06 pm
I am an absolute "believer" in synthetic oil. I had a Dodge Spirit 4 cyl that at about 150,000 miles had a valve guide work loose. Mechanic had the head sitting on the bench, and withe the valver cover off, everything was all clean a shiny - I said "Wow, did you soak that in gunk? How'd you get it so clean" - the mechanic replied - "That's how it was"...
I used synthetic in that car since it was new.
I use Mobil 1 and change every 5,000 miles.
Old 18 Jun 2007, 06:05 pm
I use Mobile1 fully synthetic, it is some great stuff!
Old 19 Jun 2007, 02:53 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Royal Purple. I spoil my car.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 19 Jun 2007, 05:58 pm
Royal Purple
Old 04 Nov 2010, 07:04 pm
Post Re: Synthetic Oil
Synthetics are the best oil you can run in an engine to date. Synthetics provide cooler running temps, cleaner emissions, and longer change intervals. Some as long as 1yr/25,000 miles. However Amsoil has a new line called the Amsoil(OE) Series and it is designed for warranty specs and 3000-5000mi oil change intervals for those who prefer it to an extended interval. Keep in mind you will want to have quality filtration for synthetics or any oils you use. If you choose a synthetic you will notice more power, better fuel economy, less friction and engine wear and tear. Try the Amsoil(OE) Series and if you want a longer change interval step-up to the Amsoil(XL) 7500mi series. Find out more about these oils and filtration at :
Beverly Synthetics - Home page
Old 04 Nov 2010, 07:44 pm
yaris's Avatar
I use castrol syntec oil and change it one time a year, which mean every 15000km, or 9000miles
Old 04 Nov 2010, 08:23 pm
I run SuperTech Fully Synthetic from Walmart for the life of the vehicle. I change it at 5,000 mile intervals. It runs great and rated up there with the other more expensive synthetics. It runs me $17.50 for 5 quarts.
The names are what drive up the price. Look it up on Google and you will see rave reviews about it.
Wal-Mart Synthetic Blend Oil Change? amazingarthur General Turbo Discussions 21 13 Mar 2010 05:12 pm
Synthetic wax coopj40 The Detail Shop 14 20 Dec 2007 01:07 pm
Synthetic oil turbomangt General Turbo Discussions 21 11 Nov 2004 05:39 pm
Synthetic Oil ? BS or true Jimbo Tech & Performance Forum 16 25 Mar 2004 06:08 am
Swiching from Synthetic oil to normal OK? iggman Tech & Performance Forum 6 16 Oct 2002 04:40 pm
