Battery good not sure if is starter or ignition
  • 1 Post By Rob in tx
Old 25 Jun 2007, 06:31 pm
Default Battery good not sure if is starter or ignition
Anybody ever have this problem. My cruiser will start some times and some times it wont. The battery is good and there are no error codes. Has anybody had a starter or ignition switch problem
Tvio likes this.
Old 26 Jun 2007, 02:13 pm
Default Re: Battery good not sure if is starter or ignition
how are the battery terminals ?? clean or dirty ??
Old 03 Jul 2007, 06:58 pm
My wife's '02 had that problem and it was the starter. It finally refused to start at all until I took the tire iron and smacked the starter a few times. Had it repaired under the extended warranty.
Old 03 Jul 2007, 11:34 pm
SRG SRG is offline
Could also be bad battery/starter cables, my wife's 03 had the same problem, changing the cable assembly fixed it.
Good Luck!
srg
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
good battery? proxeyed Tech & Performance Forum 18 01 Aug 2005 11:38 pm
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
