How to ? Check Cooling Fan '01
Old 04 Jul 2007, 09:25 am
Default How to ? Check Cooling Fan '01
Ok I've been reading 4 hours....
My '01 cooling fan is not coming on.
40a fuse is good, small relay swapped has no effect.
How do I determine failure of:
Large relay
Fan Motor (and how do you get that damm plug undone)
ECM
Thanks very much!
Pffester
Pffester02@comcast.net
Old 04 Jul 2007, 04:00 pm
Default Re: How to ? Check Cooling Fan '01
I just went through this whole procedure but here goes... If your talking about the "plug" or wiring harness connection for the fan, the red tab on the top of the connection slides to one side and lets the connection come apart. Then take both a negative wire and a hot wire and touch the negative wire to the black prong off the connection and the hot wire to either the yellow or red prong. (the prongs aren't actually colored but you can see the wires that go to each prong and they are color coded. Only one speed (I forget which) of the fan will come on when you touch the yellow or red prong but if one speed does come on, at least you know your fan motor isn't burnt out like a few of us had happen. In case your talking about some other "plug", the one (wiring harness connection) I'm talking about is accessed from the bottom of the car where you can see it in this picture with the red slide on the top.
Old 04 Jul 2007, 07:12 pm
my wires are blue/ black/ blue, but I got the damm plug apart and applied power.
Nothing....
Thanks for your help. I'm off in search of a fan.
Thanks!
Old 04 Jul 2007, 08:05 pm
Before you go anywhere, check out this thread from a turbo owner I helped out. Same problem as yours.....
Computer code # P0480
Check engine code P0304 Gary Mick Tech & Performance Forum 20 14 Mar 2010 08:50 pm
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Bulletin on the spark plugs check it out bstrips79 General PT Cruiser Discussions 18 20 May 2004 12:52 pm
Spell Check PianT Non-PT Discussions 1 23 Sep 2003 10:00 am
