Rear popping noise when braking
Old 13 Jul 2007, 11:43 am
Unhappy Rear popping noise when braking
Has anyone experianced a popping noise coming from the rear of the car while braking to a stop? This developed on my 01 PT at 61k miles, I currently have 61,500 miles showing. I had the original brake pads replaced (rear disk brakes) because of this noise. No change. I took it to a 5 star dealer and they replaced the rear track bar, cleaned and lubed the rear calipers. No change. My 5 star delaer tells me it's the new aftermarket brake pads that are moving? I think this is beyond the dealers capabilities. Ideas?
Old 13 Jul 2007, 02:20 pm
Default Re: Rear popping noise when braking
i have never heard of this problem before, who did the brake job ?? take it back to them
Old 13 Jul 2007, 07:04 pm
The popping noise started before the brake job. This is what's so puzzling....
Old 14 Jul 2007, 09:46 am
when does the noise happen?? while braking ?? accelerating ?? let us know
Old 14 Jul 2007, 01:14 pm
The noise happens when braking to a stop. Never when accelerating. I have tested various brake pedal pressures from firm to soft while stopping, the popping sound exists in either case.
Old 16 Jul 2007, 07:24 am
Even though the noise started BEFORE you changed pads.... Idiots!
Check the shock mounts and the sway bar mounts.
Old 16 Jul 2007, 02:22 pm
good idea don !!
Old 16 Jul 2007, 05:15 pm
Thanks for the idea. I'll have it looked at.
Old 20 Jul 2007, 04:08 pm
03TurboGT's Avatar
Just had the front sway bar links replaced on mine and I recall very similar symptoms...
Old 29 Jul 2007, 04:08 pm
Smile Re: Rear popping noise when braking
I took all your the suggestions to the next 5 star hopeful. They actually took me seriously. They had three different techs drive it and all concluded the noise was in the rear of the car. Then they evaluated the problem by systematically disconnecting the rear shocks, then rear sway bar, no change. Then they got creative. The last hunch was the e-brake; They decided to remove the rotors and turn them to make sure they were perpendicular to the "inner e-brake" mechanism. The theory was a brake pressure / binding issue within the e-brake. For good measure they also swapped the rear pads, left to right, right to left side. I am not sure which actually solved the problem but the noise is gone. At least I now have a responsible dealer to go too....
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
mysterious rear knocking noise was found FIXED!!:) Ctown General PT Cruiser Discussions 3 01 May 2006 12:40 pm
Knocking noise from rear end Ctown General PT Cruiser Discussions 9 22 Nov 2005 06:08 pm
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
