PT Trouble
Old 14 Jul 2007, 06:31 pm
Default PT Trouble
Bought my 02 non turbo 5 months ago now at 89000 k. It had a rough idle but not too serious. I changed plugs and wires and no difference. When the weather warmed up it started overheating. I latley found the cooling fan low speed wasn't working. Chrysler said $465 for new fan and shroud assembly. I took it apart and found it needed brushes.
The rough idle has been getting worse ,now it pings like crazy and stalls alot and really hard to start. I pu in a new battery, air filter, pcv. Checked engine coolant sensor. Still barely running. It has been showing an intermittant error code. When I checked it was miss on #2 and 3 cylinder.
Any suggestions? I'm afraid to take it in to have them change parts at my expense to find the problem.
Old 14 Jul 2007, 07:57 pm
Default Re: PT Trouble
Did you use platinum plugs and performance wires? Did you gap the plugs @.040?
Welcome to the Forum.
Old 14 Jul 2007, 08:51 pm
I agree with Hooligan. First re-check your wires and plugs. I've also heard about the coil pack (where the wires plug in) going bad. I believe there's two coils in the pack for the 4 cylinders and if one goes bad, that will affect 2 cylinders....just a thought.
Old 14 Jul 2007, 09:14 pm
I did use platinum plugs
The wires were a lot heavier than stock and had heat sheilds but I don't know if they were performance.
I'll look into coil packs though.
Would that be something that would slowly deteriorate?
Thanks for the suggestions.
Old 14 Jul 2007, 09:18 pm
I gapped the plugs for 050 because thats what was on the sticker under the hood.
After reading here a bit I changed them to 040.
No improvement
Old 16 Jul 2007, 07:33 am
Sure sounds like the classic bad wires... suppose it could be a coil pack....
I'd get Crane wires www.RaceAndStreet.Com - then you could rule out wires.
Be sure the wires are seated - new wires are hard to get to "click" - at both ends.
Old 16 Jul 2007, 02:21 pm
try the coil pack
trouble with fog light switch? twins4me General PT Cruiser Discussions 18 22 Nov 2009 04:44 pm
Trouble shifting into 3rd gear on 5-speed GT purplept General Turbo Discussions 23 28 May 2004 12:00 pm
trouble code Paw General Turbo Discussions 21 20 Oct 2003 11:46 pm
Anyone have trouble with this forum? Retro General PT Cruiser Discussions 3 20 Oct 2003 12:55 am
