engine whistle
Old 17 Jul 2007, 06:36 pm
Default engine whistle
had a whistle start this morning and checked it out when I got home. put a hose to my ear and started searching. found the whistle at the intake runner to the engine on the first cylinder on the driver side. grabbed a 10mm wrench and the bolt was loose so thought I would check the other ones and cannot get to them let alone see them. thought maybe that would fix it so started it up and still there. noise stops when gassing but constant when cruising or idling. anyone have anything to share on how to stop this vacuum leak?
thanks for your input
Old 17 Jul 2007, 09:22 pm
Default Re: engine whistle
If you found one of those 10mm bolts loose, there's probably more. Can't you get to them with a 1/4inch socket set? Not too tight, they will snap off ....don't ask how I know. The torque on those bolts are only 13 ft lbs and that's not a heck of a lot so be careful.
Engine problem BORICUA Tech & Performance Forum 50 23 Jun 2012 03:40 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
