oil pressure sending unit
Old 22 Jul 2007, 09:56 pm
Question oil pressure sending unit
Does anyone know were to find it or were to attach a manual oil pressure gauge?
Old 23 Jul 2007, 03:37 pm
Default Re: oil pressure sending unit
If you have rhino ramps you will need them to reach the oil pressure sending unit located high on the back of the engine block. It will also require a special deep socket that you can find in the "help" section of Pepboys. Some people have installed a tee fitting to run both std and mechanical oil pressure sending units at the same time. Hope this helps.
Old 23 Jul 2007, 09:07 pm
Thanks ! but can you give a little more info. I have looked on the back of the engine I can not seem to find it.
Old 24 Jul 2007, 05:23 pm
Dream4's Avatar
Oil Press Switch location:
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 24 Jul 2007, 08:24 pm
On the GT there is a foil insulator around the sending unit, and you will see a wire attached to an electrical connector coming out the end. The picture that was posted makes it look easy, but remember you have to go in from underneath the car, and reach up thru frame members etc. to get at it.
Old 25 Jul 2007, 06:50 am
Smile Re: oil pressure sending unit
Thanks the help on this forum is great!
Old 03 Aug 2007, 10:06 pm
I found a great product for adding oil pressure, temp sensors. without messing with all the existing hookups for your after market gauges.
GlowShift Gauges - Performance Gauges & Pods
Check this out
Old 17 Nov 2008, 06:39 pm
Sorry to bring this up but couls someone maybe take a pic of the actual engine with the location marked on it, that would help alot, the currently posted pic doesn't help me at all. If anyone could do that it would be greatly appreciated!
Old 17 Nov 2008, 07:22 pm
Actually, you can't get more discriptive than that pic. It's just an exact drawing of the engine. You can feel it on the right side rear of the block, but it is much easier to get to from underneath with that special socket. On a lift it's a piece of cake.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Nov 2008, 07:28 pm
Okay, I haven't worked on a PT mmuch before so I'm basically a green horn in this area. Thanks!
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
