Welcome to the forum. Sure sounds like your PT has been neglected over the years, by just driving it and doing any preventative maintenance.
~My car idles very rough. The car actually shakes. Time for a change of the spark plugs and wires. if you have to pay someone, figure $150 (parts and labor) ~It is very loud. Loud squeaking noises from the front. You can even hear it when you are in the car. Get it up on a rack. Have someone pull down on the front bumper and isolate the noise. Probably all the bushings are dried out. (cheap, lubrication spray) ~My brakes squeal the most horrendous noise. Even when they are new brakes. Who put them on? Take them back and complain. If you have drums on the rear wheels, accumulated brake dust inside the drum will cause a loud squeel. If the noise is from the front, the pads have a sensor that rubs the rotor when the pads are low. Make sure whoever put in the new pads did it right and make sure the anti-rattle clips were put back on correctly.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 07 Aug 2007 at 01:24 pm. |
What plugs would you recommend? How much do just the plugs and wires cost?
I was also thinking about switching to synthetic oil as well. Will this help anything? The squeeking sounds as if it is a fan belt or timing belt. Are those easily tightened? |
Loads of options on the plugs. A bunch of went for the Champion Double Platinum #7570. More expensive (about $7 each) but last a long time. Normal plugs will run about $2 each. Decent wires will run about $40-60. Most of us use www.RaceandStreet.com for parts. I was also thinking about switching to synthetic oil as well. Will this help anything? If your strapped for money, Synthetic oil will cost 2 to 3 times the amount of regular Dino oil, but you can go further between oil changes. Synthetic oil should also help in gas mileage by 1-2 miles per gallon. The squeeking sounds as if it is a fan belt or timing belt. Are those easily tightened? Timing belts don't squeek, they slip and you'd notice a big drop in performance and driving capabilities. There is no fan belt. Fan is electronically controlled. The other belts consists of a small belt for the alternator and a drive belt for everything else. The drive belt has it's own tensioner, no adjustments. Belts aren't easy to get too and even from underneath the car you can only see a couple inches of the belt. Inside passenger wheel well cover needs to come off for access to the belts. Wait till your brother gets out of the hospital.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 07 Aug 2007 at 01:47 pm. |
welcome and i believe crewzin has covered all points
| 2004 Chrysler PT Dream Cruiser Series 3 | skylight | PT Cruiser News and Rumors | 10 | 18 Jun 2009 08:57 am |
| 2006 PT Street Cruiser Route 66 Edition | skylight | PT Cruiser News and Rumors | 35 | 17 Nov 2007 02:39 pm |
| 2007 PT Street Cruiser Announced | skylight | PT Cruiser News and Rumors | 0 | 16 Aug 2006 08:47 am |
| 2006 PT Cruiser Pics and New Specs | skylight | PT Cruiser News and Rumors | 14 | 13 Nov 2005 08:46 pm |
| New 2005 Convertible PT Dream Cruiser | skylight | PT Cruiser News and Rumors | 4 | 11 Jan 2005 06:12 pm |
