PT Cruiser Forum Car Videos
Car Rims
Boiling water sound under the hood drivers side
  #11 (permalink)
Old 26 Aug 2007, 11:18 am
csd csd is offline
Default Re: Boiling water sound under the hood dirvers side
Thanks.
I'm checking those things, last thing, now, about the MIL, like you said , just goes off when the car is running, but not at on position, i ran the test with the key secuence about 10 times, maybe i'm doing it wrong but, i get no error.
  #12 (permalink)
Old 26 Aug 2007, 02:53 pm
CREWZIN CREWZIN is offline
If your doing the code check correctly, it should say "done" if there isn't any codes, at least mine does.
With the key in the "on" position, yes the MIL light lites up but as soon as you start the engine, it should go away.
  #13 (permalink)
Old 30 Sep 2007, 04:24 pm
csd csd is offline
Default Re: Boiling water sound under the hood drivers side
After checking all this.
It was weird now , after i fully filled up the coolant , the gallon , i put in there, there has been no leaks, no over heatings, nothing, works perfectly, but, i have stumbled into another problem, i was running like normally do, then parked and stayed in the car talking to a friend, then it started getting hot inside, the temp read 111 F,i turned on the car and the temp was in the middle, we had been sitting in there almost 1 hr, temp never went up but sat in the middle. after a few hrs. it cooled down completely.
So my guess would be that the low speed is dead in the fan or something that is not turning it on.I checked the high speed runs perfect.
I had the pt for short time, but should the low speed go on when you turn off the car?
Other thing i can't get the error codes, seems impossible with the key sequence, is there a range of time where the sequence has to be done?
  #14 (permalink)
Old 30 Sep 2007, 04:57 pm
I don't get your first paragraph. Where did it get hot? Where did it read 111 degrees?
Engine water temperature will always get hotter after you stop and turn it off as the water isn't being cooled by flowing outside air or the fan so it goes up. If the needle stays in the middle with engine running and the car's not moving, everything is running fine.
When you turn off the car, I'm pretty sure all fans stop running. My Vette fan keeps running for a few minutes but I don't think the PT has that programmed into it.
The error codes only show up when the engine lite shows up on the dial. Ignition key 3 times forward without starting the car and key left forward on the 3rd turn. If no error codes, should read "done".
  #15 (permalink)
Old 30 Sep 2007, 10:25 pm
csd csd is offline
111 F inside the car, the thermometer on top read that.
  #16 (permalink)
Old 01 Oct 2007, 06:38 am
OK. I guess I'm not too old to learn something new. My overhead console only gives OUTSIDE air temperature. The sensor is located on the crossbar between the plastic grill and the radiator.
  #17 (permalink)
Old 01 Oct 2007, 08:21 am
If you only have to add coolant after overheating - I think that is normal. Was thermostat replaced when radiator was done?
Did you bleed air out of the system? Was there a lot?
It's possible when the did the radiator they didn't bleed the system properly.
Any update?
  #18 (permalink)
Old 16 Nov 2007, 07:37 pm
csd csd is offline
Thanks i just filled it up with coolant and the overheating disappeared, i have been keeping track of the level, after 3 months the level dropped not that much just below the add line, is this normal?
  #19 (permalink)
Old 17 Nov 2007, 07:49 pm
Chameleon Chameleon is offline
BTW, the boiling / gurgling sound you were hearing originally was most likely coolant purging into the overflow catch container.
vB code is On
Gurgling sound under hood..... KIMS CRUZER Tech & Performance Forum 3 20 Aug 2007 05:57 pm
Cap in drivers side fender wheel? DannyR General Turbo Discussions 14 17 Feb 2006 02:18 pm
driver's side noise benezett General PT Cruiser Discussions 9 10 Jan 2005 05:41 pm
Review: Keystone Single Port Hood (GHD-PT1) Beacon General PT Cruiser Discussions 18 28 Mar 2004 11:34 pm
Clunking sound from rear left side Presario BJ General PT Cruiser Discussions 3 27 Apr 2003 06:50 pm
  Debt Consolidation | Online Advertising | Loans | 0 Credit Cards | Problem Mortgage
