PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Free Pt Repair Manual for all
Old 26 Aug 2007, 11:37 am
csd csd is offline
Default Free Pt Repair Manual for all
Enjoy.
Torrent file.
2001-2004 Chrysler PT Cruiser Parts & Repair Manual Software
Models covered
All 2001, 2002, 2003, 2004 Chrysler PT Cruiser Parts & Repair Manual Software
This manual contains some or all of what is listed below and so much more. From Z-A
Yaw Rate Sensor
Wiring Diagrams
Wire Harness Repair
Wiper Rubber
Wiper And Washer System
Wiper & Washer
Windshield Wiper Switch Assy
Windshield Wiper Motor Assy
Windshield Glass
Window Defogger System
Wheel And Tire System
Water Pump Assy
Washer Nozzle
Valve Clearance
Transmission Wire
Transmission Valve Body
Transmission Revolution Sensor
Transmission Control Cable
Torque Converter Clutch
Tire & Wheel
Throttle Body Assy
Thermostat
Supplemental Restraint System
Sun Roof System
Sun Roof
Steering System
Steering Sensor
Steering Column
Starting System
Starter Switch
Starter Assy
Spiral Cable Sub-Assy
Speed Sensor Front
Skid Control Sensor
Side Turn Signal Lamp Assy
Side Mudguard
Side Air Bag Sensor Assy
Shift Lock System
Shift & Select Lever Shaft
Sfi System
Seat Position Air Bag Sensor
Seat Belt Warning System
Seat Belt
Seat
Roof Headlining
Roof Drip Side Finish Moulding
Roof Antenna Pole Sub-Assy
Receiver Condenser Assy
Rear Wiper Rubber
Rear Wiper Motor Assy
Rear Wheel Alignment
Rear Suspension System
Rear Suspension
Rear Speaker Assy
Rear Shock Absorber Assy
Rear Seat Belt
Rear Door Window Frame Moulding
Rear Door Glass Weatherstrip
Rear Door
Rear Combination Lamp Assy
Rear Coil Spring
Rear Bumper
Rear Brake
Rear Axle Hub
Rear Axle Beam
Radio Receiver Assy
Radiator Assy
Quarter Window Assy
Pulley Compressor Assy
Preparation
Power Window Control System
ower Steering Link Assy
Power Steering
Power Source
Power Mirror Control System
Power Door Lock Control System
Passenger Air Bag Assy
Partial Engine
Parkneutral Position Switch
Parking Brake Lever
Parking Brake Cable
Parking Brake
Output Shaft Assy
Outer Rear View Mirror Assy
Oil Pump
Oil Filter
Name Plate
Manual Transaxle System
Manual Transaxle Oil
Manual Transaxle Assy
Maintenance
Lubrication System
Lighting System
License Plate Lamp Assy
Knock Sensor
Introduction
Instrument Panel
Input Shaft Assy
Inner Rear View Mirror Assy
Ignition System
Horn Button Assy
Horn
Hood
Heater Radiator Assy
Heater Or Boost Ventilator Control
Heater & Air Conditioner
Headlamp Protector Retainer
Headlamp Dimmer Switch Assy
Headlamp Assy
Generator Assy
Fuel Tank
Fuel System
Fuel Pump
Fuel Injector
Front Wheel Alignment
Front Suspension System
Front Suspension Arm
Front Suspension
Front Stabilizer Bar
Front Speaker Assy
Front Shock Absorber
Front Seat Belt
Front Seat Airbag Assy
Front Marker Lamp Assy
Front Drive Shaft Front Door Glass Weatherstrip
Front Door
Front Differential Oil Seal
Front Bumper
Front Brake
Front Axle Hub
Floor Shift Parking Lock Cable
Floor Shift Assy
Fender Panel Mudguard
Exhaust Pipe
Exhaust
Engine Mechanical
Engine Coolant
Engine Control System
Emission Control Systems
Drive Shaft
Drive Belt
Differential Case Assy
Cylinder Head Assy
Cylinder Head
Cylinder Block Assy
Curtain Shield Air Bag Assy
Cooling System
Cooling Fan System
Combination Meter
Clutch Unit
Clutch System
Clutch Start Switch Assy
Clutch Release Cylinder Assy
Clutch Pedal Sub-Assy
Clutch Master Cylinder Assy
Cigarette Lighter Assy
Charging System
Charcoal Canister
Chain Sub-Assy
Center Stop Lamp Assy
Center Cluster Module Switch
Center Air Bag Sensor Assy
Camshaft Position Sensor
Camshaft
Brake System
Brake Pedal
Brake Master Cylinder
Brake Fluid
Brake Booster
Brake Actuator
Body Repair
Back Door Glass
Back Door Garnish
Back Door
Automatic Transaxle Fluid
Automatic Transaxle Assy
Audio & Visual System
Antenna Cord Sub-Assy
Amplifier Antenna Assy
Air Conditioning System
Air Conditioning Blower Assy
Air Conditioning Amplifier Assy
Air Conditioner Refrigerant
Air Bag Sensor Rear
Air Bag Sensor Front
File Type: zip [CSD] Pt cruiser 2001-2004 Repair manual software.zip (11.8 KB, 1290 views)
Old 27 Aug 2007, 01:32 pm
skylight's Avatar
skylight skylight is offline
Administrator
Default Re: Free Pt Repair Manual for all
i've checked.
there is a .torrent file in the above attached zip.
however, i have not downloaded the contents from torrent.
Old 27 Aug 2007, 01:46 pm
csd csd is offline
I checked all the forum rules and couldn't find anything on the subject, not sure if i broke any of the rules, i paid for this manual, and now, i'm sharing it with all you guy's, casue of for your great help, solving problems with my car.
This file can be found on Mininova : The ultimate BitTorrent source! , which is the current sharing tracker of my file.
I hope it helps other like this forum has helped me.
Old 03 Sep 2007, 09:30 pm
pdbrains pdbrains is offline
Thanks for posting the manual location but if you don't have you torrent client running and sharing the file we can't get it.
Old 03 Sep 2007, 11:11 pm
csd csd is offline
Sorry about that i had to format my pc and reinstall everything , now it's seeing again, by the way , please seed, i've had many leaches that closes after downloading.
Old 14 Sep 2007, 04:40 pm
RHAMLIN1 RHAMLIN1 is offline
Send a message via AIM to RHAMLIN1
Originally Posted by csd View Post
Enjoy.
Torrent file.
Models covered
Yaw Rate Sensor
Wiring Diagrams
Wire Harness Repair
Wiper Rubber
Wiper & Washer
Windshield Glass
Water Pump Assy
Washer Nozzle
Valve Clearance
Transmission Wire
Tire & Wheel
Throttle Body Assy
Thermostat
Sun Roof System
Sun Roof
Steering System
Steering Sensor
Steering Column
Starting System
Starter Switch
Starter Assy
Speed Sensor Front
Skid Control Sensor
Side Mudguard
Shift Lock System
Sfi System
Seat Belt
Seat
Roof Headlining
Rear Wiper Rubber
Rear Suspension
Rear Speaker Assy
Rear Seat Belt
Rear Door
Rear Coil Spring
Rear Bumper
Rear Brake
Rear Axle Hub
Rear Axle Beam
Radio Receiver Assy
Radiator Assy
Quarter Window Assy
Preparation
Power Steering
Power Source
Partial Engine
Parking Brake Lever
Parking Brake Cable
Parking Brake
Output Shaft Assy
Oil Pump
Oil Filter
Name Plate
Maintenance
Lubrication System
Lighting System
Knock Sensor
Introduction
Instrument Panel
Input Shaft Assy
Ignition System
Horn Button Assy
Horn
Hood
Headlamp Assy
Generator Assy
Fuel Tank
Fuel System
Fuel Pump
Fuel Injector
Front Suspension
Front Speaker Assy
Front Seat Belt
Front Door
Front Bumper
Front Brake
Front Axle Hub
Floor Shift Assy
Exhaust Pipe
Exhaust
Engine Mechanical
Engine Coolant
Drive Shaft
Drive Belt
Cylinder Head Assy
Cylinder Head
Cylinder Block Assy
Cooling System
Cooling Fan System
Combination Meter
Clutch Unit
Clutch System
Charging System
Charcoal Canister
Chain Sub-Assy
Camshaft
Brake System
Brake Pedal
Brake Fluid
Brake Booster
Brake Actuator
Body Repair
Back Door Glass
Back Door Garnish
Back Door
Air Bag Sensor Rear
What format is it in, I am trying to replace thw power steering pressureswitch and needed some guidence, but the manual won't open. would appreciate the help if available.
Old 14 Sep 2007, 04:58 pm
CREWZIN CREWZIN is offline
Rhamlin1,
According to the Haynes Manual, it's pretty easy to replace the Power Steering Fluid Pressure Switch (PSPS)
1. Disconnect the negative battery terminal.
2. Raise the vehicle.
3. Disconnect the elcetrical connection from the power steering switch.
(You'll find the PSPS on the backside of the power steering assembly. To unplug the eclectrical connection, pry up on the locking tab to release it.)
4. Using a deep socket and an extension, unscrew and remove the PSPS.
5. Seal the threads of the new switch with teflon tape.
6. Installation is the reverse of removal. Be sure to tighten the switch securely.
Old 14 Sep 2007, 08:54 pm
csd csd is offline
It's a zip file with a torrent file inside, you need a bitorrent client to download the whole manual use utorrent µTorrent - The Lightweight and Efficient BitTorrent Client
Install utorrent, download the posted file , unzip and open the torrent file inside , your download will start at once.
Please seed leave it open so other can download as well.
Old 18 Sep 2007, 10:38 pm
powerstroker05 powerstroker05 is offline
Is this still working? Ive done everything. Well, maybe not everything obviously, but I still cant make it work. any suggestions?
Old 27 Sep 2007, 04:17 pm
oldcoach's Avatar
oldcoach oldcoach is offline
Got it, and it looks great, thanks CSD
2002 Black Woody
vB code is On
repair expectations - 2001 5SP njred General PT Cruiser Discussions 0 25 Aug 2007 09:37 am
Five of the lowest repair cost vehicles skylight PT Cruiser News and Rumors 4 15 Aug 2007 11:34 pm
Service manual Shini Quiet General PT Cruiser Discussions 3 18 Oct 2005 02:16 am
Best manual for an '03 GT? sawdust123 General Turbo Discussions 4 19 Jan 2005 11:46 pm
Free Image Hosting IRPT Non-PT Discussions 41 30 Jun 2004 07:58 pm
  Loans | Loan | Virtual pets | Homeowner Loan | Loans
