PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   ruff outta the blu & error code question (http://www.ptcruiserlinks.com/forum/tech-performance-forum/15683-ruff-outta-blu-error-code-question.html)
ptcruiserdad 26 Aug 2007 04:02 pm
my daughters pt started running very bad while runnin down the freeway yesterday. i ran the codes and two came up. p1684 & p0303. i gather the 0303 is from needing a tune up. can someone tell me what p1684(driver5-line5) would be ? thanks in advance.
russ
CREWZIN 26 Aug 2007 05:23 pm
Re: ruff outta the blu & error code question
Russ,
I know the list that on this forum says something about the "driver" for your P1684 code, but on other Code Lists the P1684 is nothing to worry about. Even if you've never touched the battery, you can still get this code.
1684 =The battery has been disconnected within the last 50 starts.
P303 is a misfire in Cylinder #3 and yes, it could mean you need new plugs or wires.
Oh Yea, WELCOME to the forum. :D
Hooligan 26 Aug 2007 06:26 pm
Welcome to the Forum:)
You didn't say what year nor mile age. Probably needs plugs Champion 7440, (if you do not have a turbo),they are double platinum plugs. Gap at .040, use anti seize grease. I also used MOPAR High Performance wires (can get at dealer, may have to order). On the wires use dialectric grease.
Torque plugs to 13 ft lbs. If you have a NA you will have to remove the intake, to replace torque in this sequence 5, 3,1, 2,4 at 105 inch pounds. Don't worry about the intake gaskets unless you damage one during replacement. Good Luck
ptcruiserdad 26 Aug 2007 11:20 pm
thank you crewzin and hooligan. i will pickup parts tommorrow and install. i will give update when complete. great forum.
fritz_t_coyote 27 Aug 2007 11:52 am
Just to make it clear 'Dad': Be SURE to replace the wires with Aftermarket, NOT "Genuine Chrysler".
The factory wires are of exceptionally low quality; in fact I would not be surprised if your plugs (even #3) are in better condition than the wires.
--- and welcome to the forum....
bobs turbo pt 27 Aug 2007 02:39 pm
keep us posted & welcome !!
