straw went flying into throttle body
Old 29 Aug 2007, 05:16 pm
Default straw went flying into throttle body
yes, I'm an a**...
I was trying to clean my throttle body using a can of Mopar throttle body cleaner. well, it comes with a straw so you can spray inside the actual body. guess what, the straw went flying into the throttle body!!!
now, it's a small plastic straw, I'm guessing it will melt later on and nothing will happen... any suggestions/ideas/concerns, before I shoot myself?
thanks!
Old 29 Aug 2007, 05:33 pm
Default Re: straw went flying into throttle body
My concern would be would it totally melt and not just into a small clump? Might want to talk to a certified mechanic.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 29 Aug 2007, 06:22 pm
infernocruisr01's Avatar
Send a message via AIM to infernocruisr01
Can you see the straw in the throttle body at all with a flash?
Old 29 Aug 2007, 07:53 pm
No... how dangerous can this be?
Old 29 Aug 2007, 08:22 pm
I dunno..Have you ever done a tune-up on it
Old 29 Aug 2007, 08:32 pm
Will the mechanic be able to locate the plastic straw in a tune up?
And yes, I just had a tune up about two weeks ago...
BTW, thanks for replying
Old 29 Aug 2007, 08:37 pm
The straw could be in the the lower part of the intake maybe.. and no problem to responding
Old 30 Aug 2007, 06:03 am
Those straws are usually about 5 -6 inches long. I go along with Inferncruiser01 and think it's stuck, but probably in the upper manifold.
I'd personally take off the upper manifold and hopefully be able to retrieve the straw before it gets into somewhere where it might do damage.
Old 30 Aug 2007, 09:44 am
A long pair of forceps may be needed. If you are lucky you will be able to get it with your fingers or at least make it lay down so you can shake it out.
AT Throttle Body in 5 Speed mvandale Turbo Performance 3 05 Dec 2006 12:03 am
POWERAID Throttle Body Spacer - Works?? matt87951 Tech & Performance Forum 17 23 Aug 2006 09:35 pm
Throttle Body Cleaning RAK402 Tech & Performance Forum 28 10 Nov 2004 02:21 pm
Airaid Airmax and throttle body spacers Robster Tech & Performance Forum 22 22 Jul 2004 08:12 pm
Throttle Body Air intake kjman25 Turbo Performance 7 19 Aug 2003 10:25 pm
