Small light under center console?
Old 23 Sep 2007, 01:27 pm
DJmart's Avatar
Send a message via AIM to DJmart
Default Small light under center console?
There is a small green light directly infront of the shifter, under the center piece is it a white light?
I cant seem to figure out how to get that housing out... How do you get it out?!
I wanted to replace that one with a bright LED bulb. But I think that the plastic piece is colored green, getting that off would do the trick.
Thanks fellas....
-DJ
Old 24 Sep 2007, 06:55 am
Default Re: Small light under center console?
DJ,
I was hoping someone would have an answer for you. I really don't. I looked under the dash with a flashlight and small screwdriver. I saw the black rectangle with the blue/green lens. I tried prying it off but it didn't want to move and I didn't want to break it. It may be that you have to get to the bulb from the inside by taking out the center console but I can't say for sure.
What I do think is that there probably already is a bright white LED light there and it's just covered by the black housing with the colored lens. Taking the housing off would probably give you all the extra light you need unless the housing and bulb are all in one piece then you'd have to find a way of securing the light in place without the housing.
2000 PT. 100,000 miles, Original Owner
Old 24 Sep 2007, 10:02 am
DJmart's Avatar
Sounds like more trouble than its worth....
Thanks Crewzin!
Old 30 Sep 2007, 11:03 am
PTmodrod's Avatar
Default I have done it
I know the light you are talking about and I have changed mine. I have hidden red neon lights up under the dash in the footwell areas and under the front seats. The little green light was bothering me so I popped the lens off and replaced it with a little red one I made out of a soft clear plastic. It can be done!!!!
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Center console flood light toneman Interior Accessories Forum 2 28 Feb 2006 07:34 pm
Removing Lower Center Console CHROMEDCRUISER Interior Accessories Forum 3 03 Jan 2005 10:27 am
Body Colored Center Dash Console patbluecruiser Interior Accessories Forum 20 05 Jun 2004 08:27 am
Modify the Center Console for 1 1/2 DIN Stereo erwinlg Sound and Security Forum 0 12 Dec 2003 02:56 pm
center console lchiwahs Interior Accessories Forum 19 02 Nov 2003 11:26 pm
  Debt Consolidation | Virgin credit card | Cheap Plane Tickets | Debt Consolidation | Debt Consolidation
