Engine Shut Off, Will Not Restart
Old 02 Oct 2007, 01:14 pm
Default Engine Shut Off, Will Not Restart
When my wife left for work this morning her 01 PT made it almost to the next street before the engine just shut off. I went over and checked it out and it would take several tries to get it started. When the engine turned over it would start fine, but just run for a few seconds before dying again, and then taking a while to get started again.
After I took her to work and then came back to the car I was able to start it up almost immediately and it would run long enough for me to get it back to the house.
Now that it is in front of the house, I have been able to start it up immediately like normal, not at all, and only after a few moments of waiting. So it does not always repeat the symptoms from one try to the next. Everything on the interior works such as lights, radio, gauges, locks and horn.
I was able to get a 1684 code, but the information on the forums here and other websites are conflicting.
The battery is just a couple of months old.
Hoping someone can lead me in the right direction towards getting this thing back on the road again.
Thanks.
Old 02 Oct 2007, 01:25 pm
Default Re: Engine Shut Off, Will Not Restart
The P1684 is the signal that the battery has been disconnected in the last 50 starts but a lot of us see that code and haven't touched anything. Looking through the Internet the best advice is to have the whole charging system looked at. Battery stores and some auto stores will do it for free. Even though the battery is almost new, doesn't mean it's not defective with a bad cell or a loose wire somewhere. Before you go, take off the leads and clean the posts to make sure your getting a good connection.
2000 PT. 100,000 miles, Original Owner
Old 02 Oct 2007, 01:44 pm
Doesn't sound like battery to me, since you can crank it, & lights, etc, work. Can't hurt to check battery connections.
Don't rule out the ignition switch - I saw a thread where that's what the problem was for symptoms roughly the same as yours - try holding/pushing in on key & see if that makes a difference.
Try doing a search here on ignition...
Old 02 Oct 2007, 04:43 pm
Well, at this point it is definitely the negative battery cable...as the connector just sort of broke off
So, to look up the replacement info for that...
Thanks for the responses guys.
Old 02 Oct 2007, 05:50 pm
Replaced the negative terminal. It would not start at first, but after about five attempts it started up fine. Let it run for a while and it ran OK. Shut it off and was able to start it back up without any problems. Shut it down one more time, now I cannot get it going again.
I tried to ignition switch thing (pressing the key in while trying to start it) but that did not make a difference.
What is the one red light in the middle of the fuel and temp gauge for? Sometimes it is on, sometimes not, but mostly it is.
Thanks again for looking.
Old 02 Oct 2007, 06:11 pm
The light has to do with the alarm system.
You say you shut it down and now it won't get going again. Does it turn over pretty fast but just not catching, or not turning over at all?
When it's running, it's smooth, will rev up, idle OK and sit there running without trouble?
Basically, we have two major things to look for...ignition and fuel. Unless of course there's a computer, relay, fuse, switch or other factor involved.
Old 02 Oct 2007, 06:37 pm
Will not turn over at all.
When it does run it runs perfectly normal.
Old 02 Oct 2007, 06:47 pm
Hmmm. I remember my Vette doing something like that. Turned out to be the solenoid on the starter. We do have a solenoid on the PT. Could be dead spots. You can see the starter and solenoid if you look down in front of the engine when standing at the front grill.
In the old days we used to bang/tap on the solenoid when it was going bad to get it to start. Don't know if that would work now.
Old 02 Oct 2007, 07:03 pm
Running with that idea, I found another line for troubleshooting the starter. The first thing they said was to turn on the headlights and try to start the car. If the lights dimmed then it is more than likely the solenoid/starter. However, the lights didn't dim and they recommend checking the control module.
Now, what is this "control module" that they are referring to?
Link
Old 02 Oct 2007, 07:14 pm
The Control Module or PCM ( Power Control Module) is your computer and it's not cheap.
I did a Google search and even on there under "failure to start" it was recommended to replace the PCM. We/you haven't the equipment to trace down where the fault may really be. You might have to break down and have it professionally diagnosed either by the dealer or local shop.
Chrysler Repair: follow-up Power control module, engine won't start
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 13 21 Mar 2009 02:53 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
  Wordpress Themes | Debt Consolidation | Adult ADD | Debt Consolidation | Find jobs
