Custom Wheels
P0601 error replacement parts
Old 10 Oct 2007, 02:26 am
doy doy is offline
Default P0601 error replacement parts
hi all, i have a 01 PT Cruiser with the P0601 error. read on the forums that I will need to replace the PCM part. can anyone please advise what the part number is? I got one from a friend and it's R5033117AE, but the description is MODULE ENGINE CONTRO , not PCM (powertrain control module).
thanks in advance for the time and help!
Old 10 Oct 2007, 07:41 am
Default Re: P0601 error replacement parts
There's a number of reason why you might have got the code. I wouldn't go changing modules without further diagnostics. Here's one pull from a Google search.
To answer your question, a search brings up different diagnostics for a PCM and ECM.
DIAGNOSTIC TROUBLE CODE (DTC) - P0601 ENGINE CONTROL MODULE CHECKSUM ERROR
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 12 Oct 2007, 07:31 pm
P0601 is PCM internal fault. This is the PCM saying dont bother to do any diagnostic. I am bad and therefore need to be replaced. The part number you have is for a remanufactured PCM hence the R in front of the number. If you are under 8 years and 80,000 miles you can get it replaced at the dealership under emissions warranty. If not then you will still have to deal with a dealership because the PCM will have to be programmed to the car. It will have to have the VIN and SKIM codes burn into it.
Low Quality parts in these states - we're being frauded Wrenchhed Southeast PT Forum 6 16 Jul 2007 01:48 am
Mopar Parts Now Available For Dodge SRT4 skylight PT Cruiser News and Rumors 5 10 Sep 2003 10:33 pm
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
Warranty Kirby General Turbo Discussions 6 09 Jun 2003 05:53 pm
Mopar Performance Parts Warranty Dalite Turbo Performance 0 07 Jun 2003 10:44 pm
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
