Timing Belt change
Old 23 Oct 2007, 01:58 pm
Default Timing Belt change
Heard recently of a PT owner that had his timing belt replaced at approx. 70K miles and afterward had alot of issues - major issues. I suspect the original belt stretched ? When is the recommended changeout ?
'06 PT Touring
Old 23 Oct 2007, 03:52 pm
Default Re: Timing Belt change
If what you heard is true, I would think he would have has issues before the change, unless he/mechanic did something wrong during the change.
Most of us look around the 100,000 mile mark as time to change. I'm looking around now to see where the best place to take it. I'm at 90K.
Along with the timing belt, most recommend having the water pump, belt tensioner and normal driving belts changed also as they tend to wear out with mileage and since your in the same area of the engine, your saving labor charges by doing it all at once.
Timing Belt Replacement MarkB Tech & Performance Forum 38 30 Apr 2010 07:38 am
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
After timing belt change no more Air Conditoning? Ctown General PT Cruiser Discussions 5 28 Mar 2006 01:24 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
