PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Grinding noise (http://www.ptcruiserlinks.com/forum/tech-performance-forum/16155-grinding-noise.html)
SmittysGold 24 Oct 2007 05:59 pm
Grinding noise
We bought a 2001 PT and have had it a few months. Lately, we've been noticing a grinding noise mostly when applying the brakes. We took it in for the mechanic to listen to and of course the noise stopped. We had him go ahead and replace the brake pads. The grind is still there and it is mostly when braking and when turning to the right. It sounds like metal is dragging but we checked and it's not. Anyone ever heard of this problem?
CREWZIN 24 Oct 2007 06:45 pm
Re: Grinding noise
Welcome to the forum,
Sounds almost like a wheel bearing. You've narrowed it down a bit, try and pinpoint a particular wheel. Have someone stand outside one side at a time as you brake and turn. if you can't take it back to your mechanic and have him dig deeper into the wheel.
SmittysGold 24 Oct 2007 06:51 pm
Re: Grinding noise
Thanks for the reply. The noise sounds like its on the left side. It's my daughters car and she needs it to drive to school so we need to work around that if we can. Is this something that is major serious and needs to be fixed asap?
CREWZIN 24 Oct 2007 06:59 pm
Re: Grinding noise
If it IS a wheel bearing, you don't want to drive on it too long as if it gives out all the way, the wheel could collapse while driving. If school is just a few miles one way, then it will probably last awhile, but I'm just guessing at the bearing problem. Hopefully the mechanic looked for other brake problems when replacing the pads and not just throw pads on there without looking around. There's an anti-rattle clip on each brake and if it's put on wrong, left off, bent or broke it could cause noise.
SmittysGold 24 Oct 2007 07:10 pm
Re: Grinding noise
We will take it in tomorrow then. How scary!
CREWZIN 24 Oct 2007 07:17 pm
Re: Grinding noise
Don't mean to scare you, but noise from the wheels or braking system shouldn't be ignored and it's good that your on top of it.
SmittysGold 24 Oct 2007 07:19 pm
Re: Grinding noise
Thanks for the input. I will take it in tomorrow and report back how it goes.
Hooligan 25 Oct 2007 07:34 am
Re: Grinding noise
I had a squealing noise, took it to the dealer, it was the ceramic brakes had glazed over, buffed of the glaze. Fixed for now. Hopefully yours will be as simple.
SmittysGold 25 Oct 2007 11:01 am
Re: Grinding noise
Quick question before I take it in. About how much should it cost to fix the bearings on one side? I know I should do both sides, I just want to have an estimate when I go in. I'm taking it in myself, and I know some places like to take advantage when they see the wife drive up.
CREWZIN 25 Oct 2007 11:14 am
Re: Grinding noise
Hard to say. Seeing it's a dealer, they'll probably go for about 2 hours labor plus parts plus the soap & water they use to clean up along with mopping the floor when your done and disposal of the old bearing. Of course the invoice will say it's all miscellaneous expense.
