Battery Replacement Question
Old 04 Nov 2007, 11:35 am
Default Battery Replacement Question
How many miles did you have on your PT when you replaced the battery?
2005 GT Cruiser, Cool Vanilla, Automatic, Borla Dual Exhausts, K&N, Navigation and U Connect.
2001 Corvette Convertable, Navy Blue Metalic, Z51, 3:15 with 4" inch quad Borla Stinger Exhausts X Pipe and K&N Filter.
Old 07 Nov 2007, 09:01 pm
nexium's Avatar
Default Re: Battery Replacement Question
Mine needed one at 35,000. I tried to get an Optima that would be a close fit, but they don't make a drop in. My 02 has a weird size, small, with reversed terminals. Has an insulative wrap, and some kinda temperature sensor for the battery. Maybe anything other than the scrawny original isn't compatible with the car's electrical system.
Old 13 Nov 2007, 01:30 pm
See the other thread but the Optima red & yellow fit just fine! The cable are tight but they reach.
Good luck, joel
The Pair-A-Dice PT, "my car is cleaner than yours"also more likely to burn!
Old 13 Nov 2007, 01:36 pm
Good luck, joel
Old 14 Nov 2007, 08:39 am
nexium's Avatar
Thanks for the info. I looked into the 34R and 51R. Both are 2 inches longer than my battery tray. (02 bottom of the line model). The tray is the only limiting factor. Also noticed the seemingly undersized battery cables, and the main ground to the inner fender panel is a scream.
Old 15 Nov 2007, 08:59 am
I traded my '02 (for my '05) with 87,000 miles and original battery.
My daughter's '03 GT needed a battery at 50,000+ miles - I put in a Sears dieHard.
As to cables, Go to AutoZone, etc, they have a selection - I added grounds (off the - post) to computer housing and body - can't hurt, and many say it helps (supergrounding).
Old 15 Nov 2007, 09:12 am
nexium's Avatar
quicksilver - my original battery may have died from not being used much. The car still has under 40,000 on it, and the battery lasted 5 years. I have run additional #10 "supplemental" grounds to the ECC, TB and head. One extra #4 to the starter. I've measured up to .3V differences between some "grounds" in this car. Wonder if all have the phenomena. A lot of other strappings, but they're for radio noise suppression. Thanks for the info.
Old 15 Nov 2007, 09:19 am
5 years is good for a car battery. Like many things, it's often a combo of miles/and/or years.
Old 15 Nov 2007, 03:37 pm
Smile Re: Battery Replacement Question
Well, 5.5 years and 54k miles and OEM battery still going strong in the 2002. The 2003 is original with 34k miles and 4.5 years.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Warranty question, please. dolemite General PT Cruiser Discussions 2 31 Jul 2007 09:14 pm
question on front rotor replacement? gonzomania Wheels, Tires, Suspension 4 03 May 2005 12:51 pm
Brake pad replacement question nozzano22 Turbo Performance 17 09 Dec 2004 02:42 am
Batttery Replacement stirfry General PT Cruiser Discussions 7 29 Nov 2004 06:18 pm
  Debt Consolidation | Kamala Harris | Business in 2007 | Millsberry | Debt Consolidation
