Disc Brake Pads and Rotors .
Old 08 Jul 2003, 01:02 am
Default Disc Brake Pads and Rotors .
I had recently have to replace both my front disc pads and front rotors on my 2002 PT. The dealer replaced with OEM disc pads and rotors that was very expensive. The PT had 20,000 miles on the pads and rotors. I except this is not the standard for any automobile that I ever owned.
Has anyone experience low mileage wear for disc pads and rotors?
Old 08 Jul 2003, 11:55 am
I had to have my front pads replaced at about 20K on my 2001.
Old 11 Jul 2003, 12:56 am
Send a message via AIM to Bosch
I got 25,000 out of my front set but I also really trashed the rotors for waiting so long. $230.00 for front pads and rotors I did the labor. So 20,000 is about the average, from what I have read from other PT owners..
Driving a 2001 27F Patriot Blue! Blue Flamed Floor Mats. Blue Flamed Seat Covers. Flameball blue \"Hair\" shiftknob. Blue behind the grll neons. FlowMaster Exhaust. Freedom Design Strut Tower Brace. Painted Smoothies. Road Runner horn! Meep Meep!
Old 11 Jul 2003, 05:46 am
So I came out better than I thought. Just had to replace the front pad and rotors reat 31900 miles. Guess I waited too long as well.
Nothing could be finer, than cruisin' the Carolinas!
http://www.carolinaptcruisers.com
Old 22 Jul 2003, 10:18 pm
Just Had all the pads replaced and the rotors cut at 45,000 miles I thought they should have lasted a little bit later but who knows I very happy I got that kind of mileage out of them.....Bill
2001 LE, Borla exhaust, pin striped, e&g sun visor, PT tail light covers Mopar wheels,Painted motor and calipers, neons inside and out, strobes, 3rd brake light cling
Old 03 Nov 2005, 05:54 pm
[8)]
OK... here's my deal... I have a 2002 PT with less than 30,000 miles on it! The torque convertor took a dive! I had to pay $100. for Chrysler's screw up! While it is there they noticed that the lower control arm bushings were shot! $700. to replace the arms with the newer bushings. I have owned cars (Chevys) that had over 100,000 miles and never had to replace the control arm bushings! Anyway, I called Chrysler and complained and they took care of the control arms but I have to pay another $100. They said I need front brake pads soon but I can do that myself! Sheeesh... I guess we are all Chrysler's test pilots!
It\'s Been A Slice of Heaven!
Old 03 Nov 2005, 10:46 pm
Go with ceramics, NAPA, PEP BOYS etc. No dust, you won't be sorry!!!
Old 03 Nov 2005, 11:10 pm
I've run into the 20k miles pad and rotor replacement several times with new cars, starting with my 1976 Capri II. Now I just change the pads before they get to 15k miles. Then I'm good for the long haul. Before low dust Ceramic pads came out, I used to use metallic pads exclusively...excellent wet and dry performance with minimum heat fade and they seem to last forever. Problem with metallic pads is that they don't make any noise when it's time to change them, so you have to do a visual inspection every so often and they tend to blacken the wheels. Maybe I've had bad luck, but I just don't trust the brake pads installed on the assembly line.
[8)]
Old 04 Nov 2005, 08:17 am
My opinion is that the rotors are too thin and too soft, and that the stock pads are made of compressed dust.
On my '02, I replaced the pads with raybestos ceramics, and the rotors with the best ones from NAPA - Braking was much improved, they lasted, and NO DUST.[?]
Old 04 Nov 2005, 09:52 am
I made it 40,000 miles on my original pads and they still had quite a bit of pad left when I replaced them with ceramic. The rotors were fine when I replaced the pads but now they must be warping cause I have a shimmy when breaking hard. I plan to replace the rotors with drilled and slotted after Christmas. Got to take care of those grandkids first!
NEW ROTORS & CERAMIC PADS littleblueGT Turbo Wheels/Suspension/Handling 22 06 Mar 2007 10:20 pm
Lomandi Brake Pads and Rotors CHROMEDCRUISER Wheels, Tires, Suspension 4 21 May 2005 03:18 am
Brake kits for the Pt Gt from Moparsupercenter.com JEFF@RHJEEP Vendors & Buyers Forum 0 23 Apr 2005 01:07 pm
Factory brake rotors cracking already (under 30k) braindead0 Tech & Performance Forum 6 30 Sep 2003 04:38 pm
Pads and Rotors pingber Wheels, Tires, Suspension 10 23 Sep 2003 01:01 am
  Online Name | Wordpress Theme | Debt Consolidation | Kamala Harris | Wordpress Theme
