03 Pt Turbo upgrades
Old 24 Nov 2007, 02:18 pm
Default 03 Pt Turbo upgrades
I just bought an 03 pt turbo friday. I am looking at adding a cold air intake, bov, and a jet chip. Anyone have any input on what would be the best route for these. I also noticed that mopar has a bov conversion kit, are they worth the money, and if not, what would be the next best bov.
Old 24 Nov 2007, 02:38 pm
Default Re: 03 Pt Turbo upgrades
Cold air intake - Hot air sucker, causing you to lose torque. Mod the stock air box, replace the turbo to airbox hose and get a K&N drop in air filter. A lot cheaper and more efficient.
Jet chip - Not worth the money. Get the Mopar Stage 1. Enhancements make it more than worth it.
Mopar bov - Noise maker, does nothing for performance but does sound cool. Mopar is coming out with a better one soon.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 26 Nov 2007, 08:18 am
The Stage 1 is the most bang for the buck.
If yours is an auto, here's a Stage 1:
PTCrew.com - Learn it or Burn it.
Old 30 Nov 2007, 06:05 pm
Listen to Mean Green. Don't waste you money on the "cold air" intake or jet chip. Stage 1 (the BEST mod), modded airbox and get some good piping to connect the airbox to the turbo will give you much better results. There are a couple hard pipe options available. It you look at the pipe connecting the airbox to the turbo you will see that is chokes down in the middle to act as a silencer in addition to the white "donut" in the airbox outlet. You can just pull the donut out of the airbox exit with no problems.
As for the Mopar bypass valve, yes it is mostly a noisemaker but I like hearing it so for a few bucks why not? Then you will want to start thinking about opening up the exhaust end of the equation...it goes on and on...welcome to the addiction.
Old 01 Dec 2007, 08:26 pm
overboost's Avatar
Location: Flint MI #3 in violant crimes, #2 in unemployment
how do you mod the stocker? I have a K&N open filter on it now, like the sounds it makes, but I would rather have extra ompfff instead of noise. hence the reason I have not put on the BOV yet.
I have had many turbo cars in the past from shelby daytona's to 10 second grand nationals. so I am not new to the game, only this car in paticular.
Old 03 Dec 2007, 09:00 am
Here you go:
Old 03 Dec 2007, 04:05 pm
Take the white doughnut out, cut the bottom silencer flush with the inside of the box and replace the very restrictive turbo to airbox hose that narrows down to 1 1/2" inside with another silencer. As for losing torque with an open intake here is a dyno which pretty much gives the same results as others I've seen with an open intake vs stock box.
Dyno results - PT Forums - The PT Cruiser Enthusiasts and Owners Resource
Now granted, you need an open intake with a big turbo, but with the stock turbo it hurts torque.
Putting an srt-4 turbo or PT turbo, onto a N/A PT Carchrism5 Tech & Performance Forum 2 14 Dec 2005 12:27 am
How lucky was I? (BOV install) alceryes General Turbo Discussions 27 18 Jul 2004 11:29 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
