Losing coolant
Old 25 Nov 2007, 04:32 pm
Default Losing coolant
out of my 2001 with 138K onto the garage floor right front just under the coolant fill. Maybe a gasket needs replacing in that area?
Old 25 Nov 2007, 04:49 pm
Default Re: Losing coolant
Check the cap and the overflow bottle hose.
Old 25 Nov 2007, 08:21 pm
Either thermostat or water pump.....Thermostat is fairly inexpensive to repair. Water pump.... Not so cheap.
Old 26 Nov 2007, 09:04 am
Just re-reading. 138K miles? Have you replaced the timing belt? You'd better. When the timing belt is done, usually the water pump is also replaced, since the labor is about the same.
Old 26 Nov 2007, 11:01 pm
Looks like coolant is coming from right near the thermostat housing if that is just down from the top of the fill tube. Looks like the gasket is gone. Will try replacing. Timing belt was done at 120K. Thanks
Turbo coolant hose blew-heads up! littleblueGT General Turbo Discussions 2 18 Oct 2007 08:22 pm
Losing coolant and overheating when stopped dornstar General PT Cruiser Discussions 3 24 Aug 2007 06:16 pm
lost coolant onyx pt Turbo Performance 10 27 Mar 2007 11:50 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
Coolant drain Chz Stage Turbo Kits 6 19 Aug 2003 02:58 pm
  グラビアアイドル | Debt Consolidation | Myspace Background Generator | Find jobs | Bet365 bonus
