PT - Whining from front end
Old 29 Nov 2007, 01:21 pm
Default PT - Whining from front end
I have a new whining noise from the front end.
Very noticeable above 20mph, most noticeable when slowing down
from 40mph to 20mph. Above 50mph, to much road noise to really hear the whine.
Whine:
- occurs when Driving straight down the road.
- is in time with tire spinning ( rotation) .
- When the rolling in neutral, whining stays in time with tire rotation.
( This is a 2003, PT Limited, with an automatic)
- Does not change tone or pitch while going around corners.
- revving the engine while in neutral does not change the whine.
- 120k miles on vehicle.
- New tires on car, Whine was present before new tires.
(thought it could have been the tires, replaced tires because they needed to be replaced anyway. I just bought a new set)
Any ideas on what this might be?
Thanks
Dave
Old 29 Nov 2007, 07:59 pm
Default Re: PT - Whining from front end
Sounds like a wheel bearing to me.
Old 29 Nov 2007, 10:08 pm
I believe you are correct.
The mechanic called at the end of the day to say the driver's
side wheel bearing(s) needed to be replaced. $250.00
Now a follow up.....
The mechanic said that he was only going to replace the driver's
side bearing(s).
Should both sides be replaced at the same time? ( I assume another $250.00)
Or
Can I wait on the passenger side until it needs replacing in the future?
Thanks
Dave
Old 30 Nov 2007, 04:29 pm
soonercruiser's Avatar
Red face Re: PT - Whining from front end
soonercruiser is just a littleover a year old, and the ony whining noise I have had is my wife in the passenger side front!
Old 30 Nov 2007, 04:34 pm
Dave,
Don't believe you have to do both sides but at least have the mechanic check the other side out for signs of trouble.
Old 01 Dec 2007, 02:14 pm
Not a bad idea to both at once.... The other one WILL go bad. Might as well get it done now rather than being out a car again in six months.... I would get both done.
Please help, front end shimmy survey Boomer Tech & Performance Forum 32 05 Oct 2009 01:54 pm
Front license plate placement spicy pt Exterior & Interior Styling 50 16 Oct 2008 08:52 pm
correct speaker wire harness for front speakers Curruzr General PT Cruiser Discussions 4 12 Aug 2004 04:01 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
