no start won`t turn over says NO BUS
Old 03 Dec 2007, 10:58 am
Default no start won`t turn over says NO BUS
also no wipers,horn,blinkers ths was hit and i purchasd ut with 8000 miles
Old 03 Dec 2007, 03:03 pm
Default Re: no start won`t turn over says NO BUS
Found these two replies to BUS failure on the internet. Looks like you need a better readout (4 digit code from the computer) or someone with a scanner to get a more comprehensive set of fault codes.......
The BUS is the digital data communication system that connects the powertrain controller, transmission controller, body computer, anti-lock brake, indstrument cluster, etc systems together to share information needed to run the vehicle. Because there is no number associated with the "no bus", I can't be sure exactly what is wrong with that system. Usually there should be a 4-digit number as the fault code, not just a "no bus". I would suggest that you go to either an Autozone Parts store to get a readout using a code reader, or to a shop to have the readout of the bus system. Autozone will often do the readout for free. If you get a 4 digit number of another message let me know what it is. I suspect that because the engine shuts down that the engine (powertrain) controller has failed as regards its ability to send/receive data necessary to run the vehicle. But a regular readout with a code reader is probably your best action.
The bus failure could be due to a variety of specific causes which can best be differentiated by use of a Chrysler Diagnostic Readout Box II (DRB II). Is there a chance you can find some shop with that tool?
The trans symptom is synonymous with a bus failure of some type, too. The DRB will tell you which of these reasons is the cause: short to battery, short to 5 volts, short to ground, bus + and bus - shorted together, no termination, bus bias level too low, bus bias level too high, no bus bias, bus + open, bus - open, bus+ and bus - open, not receiving bus messages correctly. Then I have the fault tree type manual that shows how to correct whichever one of these specific faults is displayed.
So let me know what resources you have there. The bus wires are a twisted pair so that would help in tracing them. The wires connect between the powertrain module, transmission module, instrument cluster, air bag module, overhead module (if equipped), and body computer. So somewhere in that data network we have an issue that needs to be found and corrected.
Old 04 Dec 2007, 07:46 pm
Depending on where it was hit you more than likely have a bus wire pinched or cut somewhere. Could also be a module... one of several? Numerous possibilities for the problem.
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Key will not turn relytgerg General PT Cruiser Discussions 11 17 Feb 2004 02:36 pm
key will not turn Beam General PT Cruiser Discussions 25 24 Dec 2003 06:38 pm
