Owner's manual does not mention a TB replacement ......Does it need to be replaced, when? and is the 2001 2.4 a NON interference engine?
Timing belt should be replaced at 120,000 miles. It is a non interference motor but I have seen them interfere!
Correct on both counts, but the school of thought with a lot of owners is 100,000 for the belt (to be on the safe side) and to go for a new water pump and belt tensioner while your at it as they both wear out and you/mechanic is in the area for the belt so might as well do the others.
Overboost,
Thinking about having the dealer do it also. Would like someone that has some experience with it and after talking with service manager and head mechanic, I was confident I found the right place after looking at a few other private garages. I'll also go for the drive belts as you did. Can I ask what the parts prices were that you got? Total will do to get a rough estimate of the whole job. Have 90K now so it won't be too long.
Better to catch it before it breaks.
Thanks for the good advice.....
Who knows of an Honest timing belt mechanic in the Fairfield, CA area? |
If - when you do, do this you may want to go ahead and replace the oil pump at the same time - NOTE: the pully on the oil pump is a "press on" pully that HAS TO HAVE a special tool required by Chrysler to be installed properly. I know this because it happend to me and I'll pass it on to all. My "mechanic" did not know this and just pressed it on, now it took 25,000 miles for the front of the oil pump to wear out and pour oil. Just thought I'd mention that.
Thank you all.....It appears that I will need a complete new engine rebuild while I replace the TB....Oh, I forgot, I guess I also need new pistons too.
Where is that Rav4 EV I wanted in 2003? |
| Timing Belt Replacement Instructions | PTFever | Tech & Performance Forum | 7 | 18 Jun 2011 01:23 pm |
| Timing Belt Replacement | MarkB | Tech & Performance Forum | 38 | 30 Apr 2010 07:38 am |
| Timing belt replacement | snakepitt1 | Tech & Performance Forum | 5 | 08 Nov 2007 05:33 pm |
| Another timing belt question thread :) ??? | Ctown | General PT Cruiser Discussions | 4 | 24 May 2005 08:50 am |
| Timing belt replacement? | mojogator | Tech & Performance Forum | 3 | 12 Nov 2003 03:30 pm |
