Bubbling noise
Old 19 Dec 2007, 08:48 am
Default Bubbling noise
This issue just started a few days ago. When I drive the car for more then 30 minutes and turn it off, I hear a Bubbling noise. It sounds like it is coming from the direclty in front of the drivers side. The noise sounds like someone dumping out a gallon of water to fast and it goes "glug/glug".
There is nothing dripping from the bottom of the car. I'm thinking it's the cooolant overflow tank. But why would it make the "glug/glug" sound?
Any ideas?
These PTs are pretty cool.
-jgclark
Old 19 Dec 2007, 08:31 pm
Default Re: Bubbling noise
how is your coolant level?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 20 Dec 2007, 09:08 am
Coolant level is a little above the hot mark in the overflow tank when this happens.
-jgclark
Old 20 Dec 2007, 11:43 pm
it sounds like its just steam escaping into your overflow bottle. when hot, the overflow bottle will be a little overfull as the steam has forced some coolant out of the system. when the system cools, itll draw the coolant back in. you could have a small airpocket in your cooling system. check your level when its cold, add up tot he cold line. it should burp itself.if not, there is a bleeder screw located under your filler neck, this can be utilized to bleed air from the system. i only suggest the bleeder when the system is relatively cool though.
Old 24 Dec 2007, 01:16 pm
Temp gauge okay? the gurgling is a sign some of the coolant is boiling.
Oil on dipstick clean?
Old 09 Jan 2008, 01:14 pm
I would replace the rad cap. You typically would not hear that much coolant gurgling into the catch can. Better safe than overheating on the side of the road. They are real cheap.
P304 misfire and loud noise Spidey General PT Cruiser Discussions 14 27 Jun 2010 10:38 am
my 2003 pt makes a squilling noise on start up circe Tech & Performance Forum 8 09 Dec 2007 08:07 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
