cooling fans not working
Old 10 Jan 2008, 10:02 pm
Default cooling fans not working
yes my cooling fans arent working fuse underhood is good. changed out relay changed out coolant sensor if i apply power to fan they work can someone help
Old 10 Jan 2008, 10:51 pm
Default Re: cooling fans not working
if the fuse under the hood is good, the relay has been changed and the sensor, that pretty much leaves the PCM. what is your temp guage reading? is it high? or does it stay cool because of the weather? does it come on when you turn on the AC?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 10 Jan 2008, 11:03 pm
doesnt come on when turn ac on just starts to rise when you sit for 20 or 30 min while running you said pcm so id have to replace the pcm to fix it
Old 11 Jan 2008, 05:36 pm
You need to replace the radiator fan. The fan motor is the problem. Trust me.
Old 11 Jan 2008, 11:13 pm
even though they operate when he provides power to it? well, the fan motor is ALOT less than the PCM, so start with the cheap stuff and workyour way up.
Old 12 Jan 2008, 08:20 pm
The fan is 2 speed - often one speed goes, so he's getting the other speed when he applies power.
Old 12 Jan 2008, 08:48 pm
What he said! I see a lot problems with the fans. I had one that the a/c would intermittantly not work at idle.... Turns out the high speed wasn't working but the low speed was. The engine would get hot enough to turn on the fan and the a/c would work. When it stopped so did the a/c..
Old 13 Jan 2008, 03:38 am
slarty, quick, i see your point now. im gonna have to agree with you guys on this one then.
Old 13 Jan 2008, 07:12 pm
the fan !!
A/C not working dexadel Tech & Performance Forum 70 14 Jul 2011 06:53 am
cooling fan no go on the low nealtotheking General PT Cruiser Discussions 4 29 Oct 2009 09:03 am
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
my OEM remote stop working like before??? Ctown Sound and Security Forum 4 30 Jul 2006 01:14 am
Cooling Fan Mod AZ_IceMan Stage Turbo Kits 3 25 May 2005 04:07 am
