Replacing O2 sensor in 2006 PT Cruiser
Old 27 Jan 2008, 12:52 am
Post Replacing O2 sensor in 2006 PT Cruiser
My dad wants to replace the O2 sensor in his 2006 PT Cruiser to help improve the gas mileage. We can't find a repair manual anywhere. Does anyone have any instructions (hopefully with pictures), that would help us?
Old 27 Jan 2008, 02:19 am
Default Re: Replacing O2 sensor in 2006 PT Cruiser
are you kicking a code that leads you to believe that you have a bad sensor? unless the car has 60k miles on it already i doubt the O2 sensors need replacing. replace the air filter, PCV valve, Spark plugs and wires (stocks are terrible), inflate the tires to proper inflation, and change your oil every 3000 miles. dont expect great mileage from these cars. the best ive pulled down with my 06 N/a auto is 24mpg, which is rediculous in comparison to the 35mpg in my old lady's Nissan altima. it is the sad reality of the PT.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 27 Jan 2008, 07:11 am
Cartman, while your there.
I've just past 91K on mine. Haven't replaced the 02 sensor. No codes, running fine.
1. Should I replace it anyway? 2. I know where it is (center of picture right above exhaust outlet) but do I need a special tool to take it out and, where the the wire that's on top of the sensor go to? Can I reach the wire end from above?
Thanks.
Old 27 Jan 2008, 08:13 pm
No, no codes showing, and there's only 32,000 miles on it, but my cousin was telling my dad that it may be bad even if a code isn't showing up. I'd be interested to know the answer to Crewzin's questions, too, about if you need a special tool and where the wire goes. I really appreciate your help. Thanks to Crewzin for the picture!
Old 27 Jan 2008, 09:11 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
even if it is bad it's covered under the emmisions warranty to 80,000 miles
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 28 Jan 2008, 12:20 am
There are actually 2 O2 sensors on the PTs, one in the exhaust manifold itself, and the other in the catalytic converter. You can purchase a sensor socket at any autoparts store, or you can use a wrench. the sockets are usually preferred due tot he fact that the sensors are usually on there pretty tight and the extra leverage of a breaker bar is required. as for replacement intervals, that depends on driving habits. Ive had to replace them at 60k on some vehicles, and others have over 100k on them and work great. 75 - 80k Is usually the recommended interval for most O2 sensors.
Crewzin - the wire that leads to the connector for the upstream sensor is only like 6in long and leads to a main harness. you should be able to reach the connector from the top without too much hassle, although if you can get under the car, from underneath is much easier.
Old 28 Jan 2008, 02:24 pm
OK, thanks. So, the wires lead to the harness then I guess they come off the top of the sensor to replace that sensor.
Thanks.
Old 28 Jan 2008, 04:46 pm
Probably have one of those "funny" clips to remove the wire.
Old 28 Jan 2008, 11:38 pm
the wires come off the sensor and lead to a connector on the harness, sorry should have made that more clear.
Old 02 Feb 2008, 12:59 pm
There is no way in god's green earth that an O2 sensor with only 30K miles on it is even close to bad. I consider myself a car maintenance fanatic. I change my tranny fluid every 3K-6K miles for Christ sakes. I wouldn't even THINK about replacing an O2 sensor until it was well over 60K miles. And if it did go bad for some reason, I'd take it to the dealership and argue it was poorly made, and not 'general wear'. Just like the time I had a car with 6K miles have the spark plug wires go bad. There's just no way.
If you're just really bored or something, you can go ahead and replace the O2 sensor closest to the engine. That's the one that primarily adjusts your O2/fuel mixture. The rear one by the cat will typically last even longer than the front sensor and it's for emissions more than fuel economy anyways.
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2006 Chrysler PT Cruiser Touring Automatic Full Factory Warranty Selling Below W $109 skylight craigslist 0 07 Jul 2007 06:56 pm
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
