Airbag warning light
Old 27 Jan 2008, 06:19 am
Send a message via Yahoo to worldwideboy
Question Airbag warning light
Hi guys,
Have a 2004 PT Cruiser classic, the other day while driver for no reason at all the airbag warning light came on, have checked fuses and they are all ok. Any ideas what has caused this and would it costly to fix.
Old 28 Jan 2008, 12:27 am
Default Re: Airbag warning light
there are a number of things that can couse that light to come on. unfortuneately you cant display airbag codes on your guage cluster. you need to take the car in and have a bodyshop or mechanic hook it up to a scan tool to read those codes. you can try disconnecting your NEG battery cable for about 10 minutes to see if that gets rid of the light. if not, then the code is active and needs attention. good luck.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 28 Jan 2008, 09:42 am
Happened to me several months ago. Light came on a while after I had really banged the horn. I stared at the light, and thought, "Great, now a trip to the dealer", and punched the horn out of frustration, and light went out! A day later, light (and chime) return - I remembered, and hit the padded center area a few times, and again light went out. Day or 2 later, light & chime again, banged around edge of the padded area toward the center, light went out and has stayed off since.
I figure a loose connector/sensor.
Old 28 Jan 2008, 01:40 pm
Thanks for the info guys, will most likely have to take it into the dealers if your suggestion don't work.
Old 04 Dec 2008, 03:45 pm
I have a 2006 Touring Edition with a similar problem. I reseated electrical connectors under the passenger seat and the problem went away.
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 24 13 Mar 2010 10:23 pm
Intermittent oil warning light sawdust123 General PT Cruiser Discussions 10 12 Mar 2005 04:45 am
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
Airbag problem - light and chime keep coming on cruiserbabe4 Tech & Performance Forum 9 22 Jul 2004 01:00 pm
remove air bag seats= air bag warning light? Punch Exterior & Interior Styling 7 02 Jan 2004 11:23 pm
