fog lamp fuse blowing
Old 29 Jan 2008, 11:18 am
Default fog lamp fuse blowing
Hi everyone...I am new...just bought a 2001 Touring Edition and I am having a couple of problems. The fog lights are not working, so I checked the fuse and sure enough it was blown...problem is every time I put a new one in it immediatly blows also...any ideas? The other issue may or may not be related, but when I turn on the interior lights manually I have to start the car to get them off...the won't turn off just using the switch. Thanks in advance if anyone has answers.
2001 PT Cruiser
Old 29 Jan 2008, 12:06 pm
soonercruiser's Avatar
Red face Re: fog lamp fuse blowing
Simple things first:
Fog lights problem sounds like a short somewhere. I'd pop the bulbs out and double check the contacts for corrosion, and the they have the proper bulb. If you are electrically inclined you can check resistance for a short there. If everything checks out there, it could be the multifunction switch on the steering column.
Old 29 Jan 2008, 12:46 pm
Default Re: fog lamp fuse blowing
WELCOME to the forum,
The interior lights. Are you giving it enough time to turn off themselves before you start the engine to turn them off. There's a built in timer (about 3-5 minutes) that goes on whenever the interior lights are lit. They go off, as I said, in about 3 to 5 minutes OR when the engine is started.
Blown fuse. I would bet on the multifunction stalk (as Soonercruiser said) being burnt out and causing a short which blows the fuse. It will cost you anywhere from $50 to $70 to replace the stalk yourself or a lot more if you let the dealer do it.
Old 29 Jan 2008, 02:41 pm
Welcome to the Forum, smilanatu. IF and I said IF you have to get a MF switch say from a salvage yard make sure it is from a PT that had fog lamps. Chrysler makes a MF switch for either Fog Lamps or non Fog Lamps.
Old 29 Jan 2008, 03:49 pm
Hey...thanks for the suggestions! As you can imagine I am about as electrically inclined as a field mouse...LOL. I could manage changing the MFS if necessary, but that's about all I got in me. Here's another question...why is there a spot for fog lamp fuses under the hood and under the dash and do I need both for the lights to work?
2001 PT Cruiser
Old 29 Jan 2008, 04:02 pm
In my 2001 Owners manual, the 20amp fuse number #21 is listed "Fog Lights (Build-Up Export Only)". Do you actually have a fuse in the #21 spot?
In the Export models (like England), the PT's have red fog lamps in the rear of the car for foggy days/nights by law. The white/red lights that we have for backing up (reverse lights) are ALL RED in the overseas models with half being reflectors and half being the fog lamps.
When I had my Corvette over in England, I had to add amber turn signal lights and a 21watt red light under the rear bumper for fog before I could take the car on the road.
Old 29 Jan 2008, 04:07 pm
Nope...no fuse in that slot. So what exactly does build-up export only mean?
2001 PT Cruiser
Old 29 Jan 2008, 04:09 pm
I added an explanation in the post above about the rear fog lights.
Old 29 Jan 2008, 04:33 pm
Okay, just for my clarity...build up export only is for oversaes back-up lights therefore I only need a fuse under the dash...which is the fuse that blows instantly.
2001 PT Cruiser
Old 29 Jan 2008, 06:51 pm
Right....as you said, there's no fuse in the #21 slot under the hood so the fuse inside the car, #8 15amp should be the only fuse for the front fogs.
Ignition Off Draw (IOD) Fuse Effects and Replacement Hints ObiMatt87 Tech & Performance Forum 15 24 Apr 2011 03:41 pm
2001 A/C Fuse BillyMcIntyre General PT Cruiser Discussions 9 30 Jun 2009 02:16 pm
Ignition Hot Fuse Under Hood? brymck Sound and Security Forum 3 03 Jan 2008 09:14 pm
Fog Light Fuse bkarr Exterior Accessories Forum 3 15 Apr 2007 08:43 am
Autometer gauges PTGT Redman Turbo Performance 12 23 Jul 2003 09:08 am
