Cold Start
Old 30 Jan 2008, 05:10 pm
Default Cold Start
I have a 03 PT Limited Edition (non turbo). For approximately a month, it takes approximately 10 tryies in the cold mornings before the engine turns over. What are the possible problems?
Old 30 Jan 2008, 05:44 pm
Default Re: Cold Start
1. Tune-Up (plugs & wires)
2. Weak Battery
Old 30 Jan 2008, 10:42 pm
agree with crewzin, also try turning the ignition on, waiting a minute, then start.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 31 Jan 2008, 03:04 pm
dirty fuel injectors ??
Old 29 May 2012, 11:11 am
I have a 2003 PT CRuiser Turbo, I recently had another engine installed, then had to replace the turbo, works great when it warms up. When 1st sarting cold engine, it stalled, bucks, and shudders until the thermostat in the cooling system opens and releases the hot water to the turbo then it runs great.
Old 29 May 2012, 12:27 pm
Milkman,
I seriously doubt that it's the hot water getting to your turbo that makes it run better/smoother after a cold start. I would check your IAC and IAT for possible malfunction. Even you 02 sensors could be causing a problem.
You give us no information about what you may have done to solve this problem or how your 03 turbo has been taken care of. When was the last time the plugs and wires were changed? What are you using for plugs and what gap are you using? What's the mileage of the engine and is your PT have the Turbo Lite or the full GT? If a GT are you using premium fuel?
Also, please don't post your question in more that one area of the forum. Makes it confusing for the people that are trying to help you.
Old 29 May 2012, 10:02 pm
UptownSport's Avatar
Sounds like it's not getting enough fuel-
Crewzin' mentioned the sensor that could be telling computer it's warmer than it really is-
Or, there may be an anti-drainback valve that's inop
Cold Start Problem Mean Green General Turbo Discussions 2 17 Jul 2004 12:37 pm
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
PTs and the "cold" yukonsly Canada PT Forum 6 30 Jan 2004 04:58 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
Cold Crank, 2nd Try. zzzhuh Turbo Performance 10 11 Jun 2003 10:45 am
