Gas in intake manifold
Old 02 Feb 2008, 04:27 pm
Default Gas in intake manifold
so i pulled off my intake manifold today and the inside of it is gas soaked.. bad.. any body have an idea what this is from?
Old 03 Feb 2008, 04:23 am
Default Re: Gas in intake manifold
are you sure it was gas? its more likely that it was oil from the PCV system hose that connects to the upper runners.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 03 Feb 2008, 11:27 am
no its definately gas... oil id understand, lol when i took the top piece of the manifold off there was gas in it, on the gasket that connect the two pieces and in the lower piece, i wiped it to make sure.. cause it smelled strong of gas
Old 03 Feb 2008, 01:27 pm
pull off the EGR hose (or unbolt rather) and see if you have gas in there. that would be the only other way fuel would get that far up the intake tract. other crazy off the wall idea might be a dirty fuel injector spraying at a funky angle.
Old 08 Feb 2008, 01:41 am
2sb 2sb is offline
Gas should evaporate off quickly once the intake was opened. Possibly a gas/oil mixture. It doesn't take much gas to impart it's smell. Is it in all the runners or just one? Just one may mean a leaking intake valve/injector. If it's in all, it's coming from the PCV and... there's probably gas in your oil. Take a good whiff of your dipstick. Good Luck!
Old 11 Feb 2008, 08:21 pm
The gas smell is normal. It comes from the vapors in the engine when fuel burns. If you look in there you will see an oil film. That's normal and that's where the smell is coming from.
Old 15 Mar 2008, 11:06 am
Hey I changed plugs last night complete job in around 45 minutes.
When I took plentum off I also found soaked intake with gas not oil my cruiser is terrible on gas I think the 2 are related This shouldn't be there since the injectors are direct into the head I am wondering if I have a restricted converter or intake.
I found a mouse nest in the brother in laws snorkle pre filter on his car (non pt) but I didn't have time to look last night on mine I will have to look closer today and haynes has a method for checking for a restricted converter I will try that too.
Old 15 Mar 2008, 09:25 pm
well thats sucks but glad to know its not just me.. everybody talks to me like i dont know the difference between gas and oil in the intake.. lol and when i say soaked.. i didnt mean alil wetness or smell.. its soaked.. if you figure out something let me know
Old 15 Mar 2008, 10:21 pm
You guys can always install a 'catch can' on the pcv hose to eliminate or at least severly reduce that oil in the intake tract. that just might be my next mod after seeing all the oil in my intake while changing my plugs.
Old 16 Mar 2008, 08:32 pm
this is not oil. I have been wrenching on cars for 20 years+ I know the difference it is gas. my car takes absolutly no oil I just changed at 5000 and not a drop of consumption. I use good oil castrol gtx. but I am sure it is gas in the plentium... acording to haynes trouble shooting this can be caused by a faulty upstream o2 sensor and unburned fuel being returned through the egr valve hense the 19 miles to the gallon, i am going to try a new bosch o2 sensor since I have 90,000 on the car and it is about time for one anyway. I will let you know the results.
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
DRILLED INTAKE MANIFOLD FOR BOOST GUAGE amx1397 Turbo Performance 6 24 Feb 2004 02:50 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
