New remote programming
Like Tree7Likes
  #11 (permalink)
Old 27 Feb 2008, 10:24 pm
Default Re: New remote programming
You need 2 keys to program another.
You only need 1 FOB to program up to 7.
If you only have one key........
You DO NOT have to visit a dealership. You only need to find a repair shop (like mine) with a Chrysler DRB-III scanner.
  #12 (permalink)
Old 09 Mar 2008, 12:04 pm
Hey not to sound dumb, but what is a drbIII scanner I have a genisis with the chrystler chip is that the same thing?
  #13 (permalink)
Old 09 Mar 2008, 01:41 pm
the drb III is the factory scan tool. for a older scan tool you can really do a lot with it, it has a built in multi meter, lab scope, its what the dealer will use to flash the differnt controlers in the non-can bus obdII vehicals.
its a great tool if you can find a mechanic that knows how to use everypart of it.
and for the new canbus vehicals they use the new scanners called the starscan, and the starmobile the starscan is nice with its color touch screen but i find it very slow, the starmobile is both a code scanner and a pass thru device, in pass thru you can use a laptop like i do and do every the star scan can do but much much faster.
the drbIII and that starscan will show a good mechanic so much more then the genisis, which can really aid in proper diagnosis of electrical fauls and dtc's so that you car can get fixed right the first time you take it in to the shop.
  #14 (permalink)
Old 18 Mar 2008, 02:25 pm
so with my wifes 06 pt with the key/keyless entery combo dohicky, if we only have one then we must take it to a shop to add another, but if she had one with the key and fob as two seperate pieces then she could program another one from that one?
  #15 (permalink)
Old 18 Mar 2008, 03:08 pm
if its the combo with only one then yes you have to take it in,
same with the stand alone key if you only have one key
but if you have just one stand alone fob then you can program a second fob on your own.
  #16 (permalink)
Old 30 Aug 2009, 11:05 am
ejstith's Avatar
From what I gather for an up to '05 PT you have to have 2 keys but only one fob. To owner program a key you have to have 2. That's what the seller on Ebay said. The fob needs only one to program a new fob ... ?????
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
  #17 (permalink)
Old 14 Sep 2009, 07:57 am
Mal Mal is offline
That is correct. The PT I bought used had 1 key and 1 FOB. I had to get a key from the dealer at $140 and used it and the one that came with the car to program a third that I bought from the internet and had cut locally. The one Fob was enough to program the second I bought from the net. I think it really important to have 3 keys and 2 fobs so the dealer or a locksmith is never required in case of a loss.
  #18 (permalink)
Old 14 Sep 2009, 02:11 pm
I followed the instructions posted here to reprogram the remote after replacing the battery. Still does not work. No beep sounds during program process. Need assistance, please.
  #19 (permalink)
Old 14 Sep 2009, 04:22 pm
Mal Mal is offline
You stated, "the remote". You cannot self program 1 remote without having a working remote. You need a working one to program another. Otherwise it's off to te locksmith with the proper tool or, heaven help you, the dealer.
  #20 (permalink)
Old 15 Sep 2009, 08:34 am
The remote that is not working is the only one I have and was given to me when purchased. Did you say a locksmith can reprogram the single remote?
Programming the keyless Remote Depot3d General PT Cruiser Discussions 73 03 Oct 2017 11:51 am
remote starters corvairbob General PT Cruiser Discussions 1 18 Jun 2005 12:13 am
Amp Remote... CHROMEDCRUISER Sound and Security Forum 4 16 Jan 2005 12:39 am
Remote Starter for 03 GT Indynick General Turbo Discussions 6 22 Dec 2004 03:44 am
Remote start with factory alarm SwtNLwPT Sound and Security Forum 0 14 Jul 2004 10:19 am
