No head or tail lights
Old 18 Feb 2008, 11:43 pm
Default No head or tail lights
Hi Guys!
Bought my PT (2002) with only brake and turn signal lights working (no headlight, tailight or fog lights). Headlight switch 'cap' was broken so I replaced the entire turnsignal/headlight double stick 'console' and still no lights. Fuses are okay, any ideas?
Aloha,
-Pila in Kona
Old 19 Feb 2008, 06:36 am
Default Re: No head or tail lights
You check the fuses under the hood, or just the ones inside? Behind the air cleaner there's a black plastic rectangle with more fuses.
Was the car in an accident? Wires may have been cut. After you check the fuses under the hood, get a meter and check for voltage at the light sockets.
Seems you already replaced the "multifunction switch" - which is the usual cause.
Old 19 Feb 2008, 09:39 pm
BLESS YOU!~ Hawaii's sh*thead electrical specialist didn't even know about the second fuse block under the hood. You've proved again, Don, FORUMS ARE THE GREATEST!~ Aloha, -Pila Chiles
Old 23 Feb 2008, 08:50 pm
I hope that squelches rumors that I'm not good for anything!
Old 23 Feb 2008, 11:44 pm
"Know ye all that "Quick Silver Don's" counsel is not only worthy it comes
with mystical powers. Thanks to him I can now see in the dark!"
-Pila of Hawaii
Old 31 Dec 2010, 06:51 pm
Did you have any power in your number one fuse? I am having the same problem and I am trying to figure out whats going. Should have power at the number one fuse and number 18 fuse. number one fuse should be powered at all times. I have no idea what's going on!
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 4 23 Oct 2009 02:31 pm
Tail Lights you've seen? PTmodrod Exterior Accessories Forum 2 13 Jan 2008 09:24 am
Jurassic Tail Lights 2step Exterior Accessories Forum 8 25 Jan 2005 07:03 pm
APC 3D Retro Tail lights looking great!!! wyzard Exterior Accessories Forum 4 21 Apr 2004 11:34 pm
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
