Clutch Master Cylinder
Old 19 Feb 2008, 10:31 pm
Default Clutch Master Cylinder
I'm trying to reduce the pedal travel needed on my 05 GT Convertible with the 2.4 HO motor. I've researched the SRT-4. Wagner shows two different parts numbers. They show the same bore. Would the SRT-4 clutch cylinder possibly help with reducing the required clutch travel needed?
Thanks,
Mike
Old 20 Feb 2008, 01:02 pm
Default Re: Clutch Master Cylinder
You would need a larger bore to decrease the amount of stroke for your clutch, and that's not something I've researched for a recommended part. There is probably another member on here who could help with a replacement part to do what you need.
clutch and slave cylinder chops660 Tech & Performance Forum 2 21 Nov 2007 01:32 pm
Review- New performance clutch install for the GT FastNJPT Turbo Performance 2 26 Sep 2006 10:13 am
